Many thanks
Will B
MR2_RICH wrote:Have/ had a similar issue mate.
One minute boosting fine the next put your foot down makes all the same noises, still boosts up to 15 psi on my gauge but doesn't actually accelerate.
5 mins later all is ok again, sometimes not.
Never got to the bottom of it and had similar thoughts re a sticking wastegage or the mbc.Haven't used the car for 3 months so I'm hoping the passing of time has magically cured it lol.
Let me know how you get on.![]()
Steve-O 2007 wrote:my timing was out by 5 degrees when I checked it![]()
A good tip is to find your timing mark with a torch(with the engine off) and put some white paint
/ tippex on the mark.
Start the car up and shine the timing light down
remember when adjusting it you have to have te1 and e1 connected
MR2_RICH wrote:Steve-O 2007 wrote:my timing was out by 5 degrees when I checked it![]()
Sorry to hijack again but hopefully my question can help others out.![]()
Why do you need to connect the pins as mentioned above? and what range should the timing be at?
Rich
