engine bay roof rack
nitric4k
Post by nitric4k »
thinking of trying build an engine bay rack tomorrow as when i keep going camping i run out of room for stuff (not a light camper)
its either build a rack up or start looking at a bigger car :(
anyone done this or is it not ideal?
platmatt8
Re: engine bay roof rack
Post by platmatt8 »
Correct me if im wrong but i think they make a roof rack for the mk2 :-k
Mr2_NA
Post by Mr2_NA »
there was a thread about some rare red mr2 with a roof rack spotted in brum :lol:
It looked bad was an overstatement.
Could try buying some of that tire goo from halfords and rid the spare wheel :thumleft:
Post by Martin F »
there was a post a couple of months ago, some guy built a frame to hold a storage box over the engine bay, looked to have done a very good job too. :-k
Post by Martin F »
Mr2_NA wrote:there was a thread about some rare red mr2 with a roof rack spotted in brum :lol:
ahh, just beat me to it mate :lol: you have to admit though it was very practical for summer camping etc. , doubt it would have been on thew car all the time :-k
did you receive the engine cover yet ?
nitric4k
Post by nitric4k »
anyone feel artistic and can think of the best way do it? any ideas welcome as its a b and q visit tomorrow :)
will kick in the old mig welder so any designs possible if not i will jump in and do it lol
Post by Martin F »
think the guy used or made bolt holes around the inspection panel compartments, then hooked the bucket about 2 foot above the engine cover :-k
BLZ-8027
Post by BLZ-8027 »
Mr2_NA
Post by Mr2_NA »
Yeah, its at the depot cos I missed them. Called them and said I would pick it up on sat, gona have to drive the 2 down with no engine lid on and fit it there :lol:
As for that roof rack :whistle:
It was indeed four steel pipes on a frame through the inspection panels, looked like it was a bog standard halfords roof box, with the frame top designed around that and the supports... who knows where they were attached.
A simple gues would be that he either welded it straight to four points in the engine bay (more likely considering the stupidity of even contemplating it)
or he made and welded four mounting points of a larger diameter tube and just slotted the frame in from the top, drill through each point and put a smooth bolt with a pin on the end, much like axel stand design.
Take into account that if its windy you may find the front unstable and you need to consider what material you will make the frame from. Steel is gona weigh abit and be hard to get on and off without help.
If i were you... go pick up a buy and sell. Find anything like a cavileer or astra or an escort with mot and tax for under £500 (not hard) and keep you two how it should be :thumleft:
You could even get a camry... when your done have the engine \:D/
nitric4k
Post by nitric4k »
wow thats got some serious storage space was thinking more something like this though tbh
then fixing it from around the edges of the engine lid
nitric4k
Post by nitric4k »
well i done it :)
my attempt after a few burns and cuts later [/img]
Post by Martin F »
robbrookes5 wrote:well i done it :)
that didn't takle long, good effort :clap: :clap:
nitric4k
Post by nitric4k »
if i could find something make the feet out of id think about making a few of these lol
costly though, must have cost about 80 quid all in :(
it clamps though the engine bay grills via a bracket, with foam tape to stop it from rattling / scratching
going give it a motorway test today bham and back :)
Mr2_NA
Post by Mr2_NA »
That is a much better effort and you havn't ruined the look of the car :thumleft:
Very impressed =P~
Quigonjay
Post by Quigonjay »
good effort, you reckon it would be big enough for a couple of drag wheels?
nigel_bytes
Post by nigel_bytes »
Found this, Says it for MR2
http://www.autolinkmx5.com/boot--luggag ... m-47-p.asp
Aftermarket item, made in England, easy to fit and remove. Note this will NOT fit mk3 MX-5's (2005 on) or cars with a rear spoiler. It clamps on the side edges of the boot lid and has rubber feet to protect the paintwork. Width (side to side) 89cm, depth (front to rear between feet) 45cm (rack itself 38cm), height (above boot lid) 10cm.
This will also fit other cars, such as BMW Z3, Triumph TR, Fiat Barchetta, Morris Minor, Toyota MR2, Porsche 944 convertible, Smart Roadster, etc.
nitric4k
Post by nitric4k »
Quigonjay wrote:good effort, you reckon it would be big enough for a couple of drag wheels?
not lying flat but i cant see no reason why if you make one ya cant sit the tires between the bars and weld support each side to hold the upright
weight might be a problem as its resting on the engine lid
the stuff i need carry is all very light
tent- and rucksack with cloths soi not going be tremendous weight
thanks for that link the fittings kit is just what i need for next time will make the feet 100x better :)
SimonPearse
Post by SimonPearse »
why do people always fit boot racks the wrong way round? The raised bar is not to stop stuff falling off the back of the car under acceleration, its to stop stuff sliding forewards under braking (a much more violent force)...
SamUK
Post by SamUK »
Top work Rob!
I want something similiar to hold my snowboard but the actual board is as wide as my car so im not sure how id do it.
Rev 3 GTS
chr15_84t3
Post by chr15_84t3 »
SamUK wrote:Top work Rob!
fit a couple of brackets onto the spoiler at an angle for a bit of extra downforce? :whistle: lol
