Garrett GT3037 Turbo
Bender Unit
Post by Bender Unit »
Does anyone know the specification of this turbo and also possibly a compressor map?
Also has anyone had prior experience of this turbo as I would be interested in your impressions regarding spool time, general response etc.
Needing to decide on a turbo, otherwise I may have to refit my stock CT20 to get the car back on the road for the time being.
Regards
James
stevecordiner
Re: Garrett GT3037 Turbo
Post by stevecordiner »
Thought this post might be of interest. Taken from the US boards
"Mitsu
16g = 34lb/min
EVO III Big 16g = 42lb/min
20g = 44lb/min
Garrett
50-trim = 47lbs/min
57-trim = 49lbs/min
60-trim = 50lbs/min
60-1 = 65lbs/min
62-1 = 70lbs/min
GT Turbo's
GT25R = 42lb/min (60trim, .64a/r turbine)
GT28R =28lb/min (60trim, .64a/r turbine)
GT28RS =30lb/min (62trim, .86a/r or .64a/r turbine)
GT30R =55lb/min (56trim, 1.06a/r or .82a/r turbine)
GT35 = 60lb/min (52trim, 1.18a/r turbine)
GT35R =65lb/min (56trim, 1.06a/r or .82a/r turbine)
GT30 (ball bearing) turbos:
48 trim = 44lbs/min
52 trim = 50lbs/min
56 trim = 55lbs/min
60 trim = 60lbs/min
gt35 trim = 65lbs/min
Turbine Conversion:
Mitsu = Garrett
6cm2 = .41 a/r
7cm2 = .49 a/r
8cm2 = .57 a/r
9cm2 = .65 a/r
10cm2 = .73 a/r
11cm2 = .81 a/r
12cm2 = .89 a/r
((CM x 8) - 7) / 100 = a/r ratio
Available Turbokits
Gen III interchangable/available (special order/directly from japan) *
KO Racing
46 Trim - 300rwhp - 330rwhp
50 Trim - 350rwhp - 430rwhp
ATS
20G - 350rwhp - 435rwhp *
CT27 - 260rwhp - 310rwhp *
eXtremeboost
GT28R -280rwhp - 300rwhp *
GT25R - 300rwhp - 400rwhp *
GT30 - 350rwhp - 450rwhp *
GT30R - 350rwhp - 500rwhp *
GT3071R - 350rwhp - 500rwhp *
CT26/35R - 350rwhp - 450rwhp *
GT35R - 500rwhp - 600rwhp *
Greddy
TD05 18G - 300rwhp - 350rwhp *
TD06 20G 8CM2 - 350rwhp - 415rwhp *
TD06 20G L2 - 350rwhp - 415rwhp *
T67 - 350rwhp - 450rwhp *
T78 - 500rwhp - 600rwhp+ *
T88 You've got to be kidding me.
HKS
HKS Sport TD05 16G 8CM2 - 280rwhp - 300rwhp
Toyota
CT26 (MR2) - 200rwhp - 260rwhp *
CT20B - 260rwhp - 300rwhp *
Apexi
RX6 350rwhp - 450rwhp *
Blitz
Blitz Bag - 260rwhp - 300rwhp *
Blitz K1 - 300rwhp - 350rwhp *
Blitz K3 - 350rwhp - 450rwhp *
Power Enterprises
PE1919 - 300rwhp - 350rwhp *
HPO
GT3037 - 350rwhp - 450rwhp *
Some of these turbo's are more capable of making more HP than the above figures. Feel free to add other turbokits I've forgotten to mention"
Small turbos - they're not big and they're not clever!
Just say NO to small turbos!
Hedgehog Dodger
Post by Hedgehog Dodger »
Bender Unit wrote:Does anyone know the specification of this turbo and also possibly a compressor map?
Regards
James
James
I have the 3037s on my motor and it starts to spool at about 3000 revs and full boost is reached at about 3600 Revs. Nice kick too :wink: :D
Bender Unit
Thanks for the info Steve, I have come across that post but it doesn’t seem to answer many of my questions. :S
The manifold I have will take a T3 exhaust flange, I intend to run a T3/T4 for obvious reasons. I was trying to gauge the performance and specs of other turbo’s on the market to help me decide the specifications of the turbo I will fit.
Thing is I am getting quite confused by all of the information. I have read RickyB’s power primer on compressor maps and how to calculate the power from a turbo etc. However there seems to be a lot of other conflicting information out there as to what turbo’s work and what don’t.
I was thinking about the 3037 as it seems to spool relatively quickly and can also make some decent power. I suppose its safe to presume that 450RWhp is around 500FWbhp. As the car will no longer be a drag car response is more important to me than outright BHP.
What do you reckon?
Dan,
Thanks for the information regarding your experiences with the turbo. Sounds good and if it can deliver the goods I am after power wise. Its just trying to find out what sort of compressor / turbine it has.
Regards
James
LimeyMk1
Post by LimeyMk1 »
http://www.turbocalculator.com/garrett-t3.html
Has a fair bit of useful info on the T3 and GT series
HTH
Chris
