Hi when a turbo timer is in countdown is it possible to arm your alarm system to lock the doors or do you not have to bother with the alarm and just lock the doors with the key? thanks
You can lock the car with the key during count down but if you have a Cat1 Alarm / Imob then you can't arm the car untill its turned off.
If you can Arm your car while its counting down and you have a Cat1 alarm then your alarm is fooked / not installed correctly
