[Mk2] [Turbo] what clutch
Hey chaps my clutch is slipping and i going to change it i have abudget of around 200 but i wanna get a slightly uprated one so if i wanna run upto around 300hp i can any links be good
Re: [Mk2] [Turbo] what clutch
standard one is good for 300hp.
so is the exedy
£116 on ebay.
so is the exedy
just got the exedy one off ebay fitted
cant fault i and for 115 quid it does the job
not sure what kinda power it can take thou
you say good for 300 but will it last i rather one that good for around 350
should be fine, if you want to go higher you'll have to up your budget to about
£300 for the clutch
then
+ fitting, gearbox oil and drive shaft seals
(seals not essential i suppose but you may as well whilst its all out.
ok went for a exdey stage 1
