jonb- wrote:The fuel sender gauge is in the top of the fuel tank and can be accessed from under the dash.
My understanding is it's a ball and float system which can sometimes get stuck.Pulling it out and giving it a good clean might help.
FYI i've never seen this sendor, just read about it so i could be totally wrong on what it is.I'm right about where it is though
3sgte wrote:i have had my sender unit get stuck 3 times
eachtime i just undone the screws in the sender and gave it a tap and done the screws back up but i have since changed the sender because the warning light part stoped working
the sender is one of the simplest things to change on the mr2, 2x 10mm nuts 5screws and a bit of wiggling and its out
,, it probably takes longer getting the radio surround and ashtray out of the way than actually changing the sender
just be careful when you remove the sender, you will be exposing the fuel vapours to potenetial sparks, best not to smoke
, in fact probably wise to disconnect the battery
osborne0 wrote:I still have the same problems as in my previous message shown above.
Last week I found a MR2 in a local scrap yard so bought another sender unit.I have the exactly the same fault!
- the gauge goes up to just under half a tank when the tank is full but starts dropping once the petrol in the tank goes below half a tank.
Is there something in the tank that would stop the float from going fully up?
