Wheel Threads
01smiffy
Wheel Threads
Post by 01smiffy »
Sorry Another wheel question!
Im am looking at buying 18" set of wheels! I have tried to fit them and will need to to put a 5mm spacer on, which isnt leaving me much thread!
How hard is it to put in longer threads?
Munnsy
Re: Wheel Threads
Post by Munnsy »
really simple bud,
Jack the car up and place on axle stand
Remove the wheel
Undo the 2 17mm bolts that hold the calpier to the hub
You will then see there is a void area behind the hub, line up the stud you want to remove to this area, hit the stud pretty hard with a hammer until you feel it to slowly nudge back towards the car, Make sure again its lined up and hit until it is removed.
To replace, all i did was place the new stud in, get an old wheel nut and wind it in until the stud sits flat to the back of the hub :thumleft:
Be carefule and make sure the stud does go in square or you will have to remove it and start again.
Key is take your time, and watch your fingers.
I had all 4 hubs studs extended on mine and only took me a couple of hours, you will get a feel for it once you have dont the first few then you will fly through the rest matey :thumleft:
Hope this helps and good luck :wink:
dave
01smiffy
Re: Wheel Threads
Post by 01smiffy »
Cheers mate
thanks for the write up, gives me a good idea!
You make it sound quite simple!
Munnsy
Re: Wheel Threads
Post by Munnsy »
It really is very simple bud,
Any probs feel free to mail me mate :thumleft:
dave
