[Mk2] [Turbo] N/a Exhaust on a Tubby
platmatt8
Post by platmatt8 »
Just wondering how loud an NA exhuast would be when fitted to a tubby?
Anybody had experences with this?
Im asking because i love the look of blueflames Na exhaust and not there tubby exhaust.
fearless
Re: [Mk2] [Turbo] N/a Exhaust on a Tubby
Post by fearless »
people change n/a to tubby so i cant see why a decent welder could adapt it to fit to be honest, only thing wouldnt pipe diameter be bigger for the turbo than an n/a im sure someone will correct me :thumleft: :thumleft: :thumleft:
Cj82
Post by Cj82 »
I had a Nur Spec on my n/a and god was it loud !! be warned lol
uglee
Post by uglee »
An N/A exhaust on a turbo should be extremely quiet. As N/A's don't have the noise deadening of a turbo there is much more baffling in them. It's when a turbo exhaust goes on an n/a that the opposite happens, mentally loud!
You can probably do it, but it might be a little restrictive due to that baffling.
I had a very quiet system on mine which used to be a turbo, and it's is hellishly loud now I have the V6. Needs another silencer in there to be honest if I want to keep the backbox.
platmatt8
Post by platmatt8 »
I`ve had an email off blueflame and they won`t attempt this design but the search will continue :thumleft:
mk2too
Post by mk2too »
if the system is the same; i haven't looked but could you get a exhaust shop to cut off the two pipes and weld on angled ones with smaller tips onto that?
Assuming its only the tailpipe design your not a fan?
platmatt8
Post by platmatt8 »
the 2 designs are completly different, na has the same style box as stock and turbo has 2 seperate silencers.
platmatt8
Post by platmatt8 »
Spoke to blueflame, their going to talk to the fabricating chaps and see what bespke system they can produce for me. :D
platmatt8
Post by platmatt8 »
well had a chat with the fabricator today and he said providing he could mandrel bend the 3" with out restricting gas flow then it could be done but im looking at an estimate of £650 :shock: :shock:
2tonemr2
Post by 2tonemr2 »
thats expensive but saying that i paid 500 quid for a crappy single exit powerflow system to be made il give it its due its held up well very nicely made and sounds the nuts i shall be modding it ti fit turbo
