nofearmadbiker wrote:im sure you will find something else trev![]()
Turbolad wrote:redmr2, what bulbs and resistors did you use for the red lighting on the buttons?
looks good.same effect as i'm after
BLZ-8027 wrote:on this picture you can see the lines going down the clear plastic,
this is where i drilled, first with a couple of leds,and then with fibre optic wires
,neither of which worked
On the clear plastic you dont need to seperate the two bits,i only did so i could get it on the bench grider easy
,and its only temporary
,when i finally figure it out ill make a better job of the one in the car
I dont have headlight levelers just the traction control button to figure out
what did you use for the indicator arrows?
Oh and the door pockets,footwells and ignition ring are wired together so they fade out after a while,
I need to work out have to get the interior lights to come on when you unlock the door because Next job is something like this(i think it will look good when you approach the car and unlock with the remote
,the handle lights up
,along with the mirrors unfolding
any ideas![]()
