Chris wrote:Not same Knock.The sensor is for pinking/det.
I know alot of these cars failed in the same way as yours.
.Usually goosed the engine
Rogue wrote:If you can get it across to Rogue HQ I'll give it a quick listen and let you know what it's most likely to be.
Cadde wrote:I have a MR2 MK3, 2002 model just had a pre cat frailer about a week ago.After getting my car back a couple of days I noticed a noise
(like a bracket is loose) when at 2000 RPM at a standstill, or aprox 4000 RPM when driving.
Took it back to the garage and they think its a piston knocking, but I think/hope hes full of bull S##t .can anyone help?
Cadde wrote:No too much engine noise, only intermittent noise like something is loose when accelerating.![]()
Any advice for a novice on what to check?
Captain Vimes wrote:Does it sound like this:-
http://smg.photobucket.com/albums/v288/ ... Broken.flv
Cadde wrote:Hmm.Could be that a part of the new exhaust section is touching a part of the bodywork
/ chassis
- I'd check that all the rubber dampers for the exhaust are fitted properly.
I'd try knocking/ rocking the exhaust by hand when cold, and see if you can replicate the nose
- and track it down from there.
Failing that, if you're close to Patrick's place, I'd take it for him to have a quick check on.
I did try that, knocking the exhaust so think Patrick's my last hope
