Wideband Option: AEM w/ Gauge
GT35R turbocharger kit
Wolfkatz Top Feed Fuel Rail
Top Feed Fuel Injectors 850cc
Large intercooler
Intercooler Pipes
2xSpal fans for top of intercooler
Oil catch tank
Oil cooler
91-95 TOYOTA MR2 TURBO 2.0L ACL RACE BEARINGS SET 3SGTE
TOYOTA MR2
Samco coolant hoses
Samco ancillary hoses
Aeromotive fuel pressure regulator
TOYOTA MR2 CELICA TURBO 3SGTE HEAD GASKET SET
JE Forged pistons 86.5
HKS cams
Water pump
Head gasket set
Bottom end gasket set
MR2 SW20 Turbo Cam Timing Belt Tensioner up to 11/93
88-01 TOYOTA CAMRY CELICA MR2 TURBO OIL PUMP 3SGTE 5SFE
ARP Head Studs 3SGTE
ARP Main Studs 3SGTE
TRD Sport Thermostat Gen2
Stage 3 6 point racing clutch
11lbs Lightened flywheel
As the title, can anyone think of anything else? Anything thats i should change while its all out, that bit that always breaks or the bit you regret not changing.
Power goal is 400bhp+ should see a lot more but dont want to worry about blowing bits and pieces.
I'm also fitting coilovers, full bush set, full uprated brake set, etc.
Thanks Dave
