PC9-406 HARNESS OR PC9-411
I AM TRYING TO GET HOLD OF A HARNESS 4 MY ACTIVE SPEAKER SYSTEM I AM FITTING A KENWOOD STEREO.I SEEN A PIC OF THE PC9-411 AND IT LOOKS THE SAME WITH 8 PINS ON BOTTOM AND 6 ON TOP BUT IT SAYS FOR 1994 ONWARDS MINE IS 1990.WHICH SHOULD BE A PC9-406.WHERE CAN YOU GET THEM FROM?IF I CARNT GET THEM I MAY RE-WIRE THE SYSTEM
,CAN YOU RE-WIRE THE ORGINAL AMPS BACK UP OR IS THAT TO DIFFCULT AND BETTER FITTING A NEW ONE?I HAVE THE SOUND SYSTEM BOX BEHIND PASSENGER SEAT WILL THIS DEFINTELY NEED A AMP TO SOUND RIGHT.THANKS STEVE
Re: PC9-406 HARNESS OR PC9-411
PC9-406 if active speakers
PC9-411 if active speakers
Google is your friend:
etc etc etc
stereo connector
Hi Steve halfrauds do the lead you require i am sure but when i found out how much it was i rewired my system removed the amps fitted a iso connector for future proofing fitted good quality cable to all the speaker mounts and fitted new speakers a amplifier under the passenger seat and two ten inch subs and six be nines on
top right near my ears
it's so loud you cant turn it right up and drive without blurry vision if you need any info on how to get at the old amps and wiring pm me
"remove them its for the best"
: Good Luck Mike
