Speedo working spot on now, there are 3 Capacitors on the speedo, all 25v, the big one at the front is 100 Microfarad, the one on the end was 6.8, the one at the back is 2.2.
I replaced the 100 and 6.8 Microfarad cap's but it was the 6.8 that was faulty, you could see rust/leak were the board meets the pins, when i removed it you could see the leak at the bottom.
All of these i got from Maplins, they were the low profile caps, i could not get 25v ones so got higher, below are the codes from Maplins just incase.
KQ63
- 6.8uF 50v
KQ70
- 100uF 25v
KQ65
- 2.2uF 35v
If i was going to do it again i would have gotten something to help remove the solder, other than that it was an easy job.
Here's the faulty cap.
And here's the actual leaking capacitor.
