Suspension Geommetry on a MK1
Categories: MR2 Mk1 Articles -> Suspension
[url=https://www.imoc.co.uk/app.php/kb/viewarticle?a=131]Knowledge Base - Suspension Geommetry on a MK1[/url]
Hi All,
I thought i\'d pass on some stuff I found out from playing with the geo on track.
Have just got back from a very good weekend at Anglesey, had two days on track with today being a bit special as it was private so only had to share with 8 other cars.
Obviously this gave me the ideal opportunity to experiment a bit with setups and to try and build a picture of how the car handles on the limit.
I started off with what was a bit of an experimental setup I had been using.
Basically set front Toe to 0.2mm toe-out
It should be remembered that stock is within 1mm of the setting so my setup wasn\'t miles different.
Camber was maxed out and is approximately 1.5deg neg on front and a little more on the rear.
To some degree this is also evident with toe and particularly so on the rear when the track rod passes the horizontal less toe-in will be the result.
so as you can see the geommetry will affectively change both in toe and camber as the suspension compresses when cornering, so really the static settings are not necessarily where the suspension will be under load, but all you can do is try a static setting out and change it according to how the car feels.
I was concentrating on the toe settings as this seems to make the biggest differences.
Just to give some background the car is an SC running 195/50/15s
Anyway onto the track stuff.
I tend to use School Corner as a test for the handling as its very fast and quite long so you can feel the car load up, balance the throttle and get a really good feel for whats going on particularly so as theres a bit of change in elevation which tends to highlight the handling characteristics.
First few laps out and the car really felt like it was almost
After a few more laps and an obvious increase in front tyre temperature it was better but still frustrating to feel that the car wasn\'t biting at the front end.
However, though MK1s do tend to understeer
So day 2 and I was determined to have another crack at the geommetry.
So off I went and for the first couple of laps there was slight decrease in the understeer turning into School.
Lap after lap it was just getting better and better and it was becoming really nice through the mid speed corners as it was simply a matter of steering on the throttle and getting the steering wheel completely straight way before the apex and just drifting the car through the apex with my right foot right to the exit and onto the straight.
It has taken me a long time to get the car how I want it, but after a three years I think i\'ve got there in terms of how it performs both down the straights and more importanly round the corners.
Cheers,
Lauren
