Gutting the catalytic converter
[url=https://www.imoc.co.uk/app.php/kb/viewarticle?a=11]Knowledge Base - Gutting the catalytic converter[/url]
by Leon\
I did this the other week, and have to say it was a complete ball-ache of a job that took me about 10 hours altogether! My tubby is a rev2 but I\'d imagine the process will be almost identical for the rev3.
It sounds easy on paper- there are about 10 bolts holding 2 covers under the car, remove these along with covers.
You\'re now left with 6 bolts and 2 nuts holding the cat pipe in place.
There\'s also the cat temp sensor screwed into the bottom of the cat pipe.
Whichever order you tackle these nuts/bolts is up to you.
My cat temp sensor was seized beyond belief so I cut the wires leading to it.
Once off the car, the gutting part took about 3 seconds- my cat internals were loose and just fell out when the pipe was turned upside down.
I\'d been told that you got a dash warning light if the cat temp sensor was disconnected from the ECU, and was planning to re-connect the wires I\'d cut but I never got a warning light anyway so I just left them cut.
I\'d suggest you buy new bolts, nuts and gaskets prior to the job so that you don\'t have to worry about snapped bolts and leaking old gaskets.
