The main differences between the two struts are highlighted in the images below
It had been suggested in he past that it would be possible to fit a mk1b rear upright to a mk1a in conjunction with the later strut.
I designed a spacer that would allow the mk1b strut to bolt to the mk1a upright, as well as adjusting for the difference in width between the upright and the strut the spacer also allows the mk1a 12mm bolt to be positively located within the 15mm holes in the strut casing.
Fitted the rear coilovers today
