waynestoyotamr2 wrote:This is the bit where Lauren comes in and trys to sell her Turbo manifold again!!
limeymk1 wrote:And I have plenty of sources for other manifolds, injectors(cheap MrT ones) and info!
Megatron wrote:However, you'll spend quite a bit of money on either conversion, for not a lot of return..
IMO!
Megatron wrote:To do everything for the conversion has cost me£1900
Icsunonove wrote:Chris you didn't tell me this![]()
Please go on..
mr2mk1chick wrote:Have no knowledge of turbo engines(apart from a bit fat turbo sits in the engine bay!), but can a regular engine be convereted? if not
- why not?
(want to learn)
Icsunonove wrote:Megatron wrote:However, you'll spend quite a bit of money on either conversion, for not a lot of return..
IMO!
John it depends on who does it for you.And as for not a lot of return, I don't understand that.
I have been informed by a number of people that the 7-rib later block is good for up to 250hp.
Well I'm aiming for about 200hp so we'll see what happens.
Icsunonove wrote:Megatron wrote:To do everything for the conversion has cost me£1900
How on earth did you manage to do it that cheaply.
You have done well.
Icsunonove wrote:And John, PLEASE tell me you are still coming to the Elvington trackday.Correct me if I'm wrong but no-one has had a Mk1.5 on the track have they? It should go like a rocket, I can't wait to see it.
Tom
feral4mr2 wrote:many people around the world have turbo'd stock 4age's with good results.![]()
good intercooling, aftermarket engine management with
proper
tuning is what you need.
high compression and boost will normally give better fuel economy and higher HP levels when done right.
my current intrim 4agte i run a 7 rib bigport 4age with the stock 9.4:1 casties at 12psi of boost.i did whack in a thicker HG set-up though as i am still useing the 4agze ECU configuration.
i've been flogging the absolute crap out of this engine for over 2 years now.
feral4mr2 wrote:i did whack in a thicker HG set-up
