I read on many forums about 0w and 5w oils being too thin.
0w-40, 5w-40, 10w-40 and 15w-40 are all the same thickness (14 centistokes) at 100degC.
Centistokes (cst) is the measure of a fluid's resistance to flow (viscosity). It is calculated in terms of the time required for a standard quantity of fluid at a certain temperature to flow through a standard orifice. The higher the value, the more viscous the fluid.
As viscosity varies with temperature, the value is meaningless unless accompanied by the temperature at which it is measured. In the case of oils, viscosity is generally reported in centistokes (cst) and usually measured at 40degC and 100degC.
So, all oils that end in 40 (sae 40) are around 14cst thickness at 100degC.
This applies to all oils that end in the same number, all oils that end in 50 (sae 50) are around 18.5cst at 100degC and all oils that end in 60 (sae 60) are around 24cst at 100degC.
With me so far?
Great!
Now, ALL oils are thicker when cold. Confused? It's true and here is a table to illustrate this.
SAE 40 (straight 40)
Temp degC.........................Viscosity (thickness)
0..........................................2579cst
20..........................................473cst
40..........................................135cst
60..........................................52.2cs t
100........................................ 14cst
120.........................................8.8cst
As you will see, there is plenty of viscosity at 0degC, in fact many times more than at 100degC and this is the problem especially in cold weather, can the oil flow quick enough to protect vital engine parts at start up. Not really!
So, given that an sae 40 is 14cst at 100degC which is adequate viscosity to protect the engine, and much thicker when cold, how can a 0w oil be too thin?
Well, it can't is the truth.
The clever part (thanks to synthetics) is that thin base oils can be used so that start up viscosity (on say a 5w-40 at 0degC) is reduced to around 800cst and this obviously gives much better flow than a monograde sae 40 (2579cst as quoted above).
So, how does this happen, well as explained at the beginning, it's all about temperature, yes a thin base oil is still thicker when cold than at 100degC but the clever stuff (due to synthetics again) is that the chemists are able to build these oils out of molecules that do not thin to less than 14cst at 100degC!
What are the parameters for our recommendations?
Well, we always talk about good cold start protection, by this we mean flow so a 5w will flow better than a 10w and so on. This is why we recommend 5w or 10w as the thickest you want to use except in exceptional circumstances. Flow is critical to protect the engine from wear!
We also talk about oil temps, mods and what the car is used for. This is related to the second number xw-(XX) as there may be issues with oil temperatures causing the oil to be too thin and therefore the possibility of metal to metal contact.
This is difficult to explain but, if for example your oil temp does not exceed 120degC at any time then a good "shear stable" sae 40 is perfectly capable of giving protection.
"Shear stability" is important here because if the oil shears it thins and that's not good!
However, if you are seeing temperatures in excess of 120degC due to mods and track use etc then there is a strong argument to using an sae 50 as it will have more viscosity at these excessive temperatures.
There are trade offs here. Thicker oils cause more friction and therefore more heat and they waste power and affect fuel consumption so it's always best to use the thinnest oil (i.e. second number) that you can get away with and still maintain oil pressure.
I hope this helps explain a bit.
Guy.
[All] [Generic] Are 5w and 0w oils too thin?
- IMOC Affiliated Company
Use the code IMR2OCUK and get 10% Club Discount
oilman's website: http://www.opieoils.co.uk/ register for news and offers
email: [email protected]
phone: 01209 202944
phone: 01209 202944
Re: [All] [Generic] Are 5w and 0w oils too thin?
as ever excellent info
allan welsh wrote:as ever excellent info
x2
can we have some of oilmans posts as a sticky please mods?
quigonjay wrote:can we have some of oilmans posts as a sticky please mods?
phone: 01209 202944
phone: 01209 202944
Almost as good as the first time it was posted:
http://www.imoc.co.uk/forums/viewtopic.php?t=10764
Gets my vote for a sticky this one, very intersting read
Rogue wrote:allan welsh wrote:as ever excellent info
lol and I posted it in june as well!
2 years ago mind.
phone: 01209 202944
phone: 01209 202944
oilman wrote:lol and I posted it in june as well!
And on one or two other forums:
http://toyotaownersclub.com/forums/inde ... pid=644228
http://www.corsa-c.co.uk/forum/showthread.php?p=1622179
http://bbs.rsownersclub.co.uk/showthread.php?p=1104876
http://bbs.scoobynet.com/general-techni ... -thin.html
http://www.gtr.co.uk/forum/upload/45950 ... ation.html
http://www.driftworks.com/forum/technic ... -thin.html
...and even in Spanish!
http://www.clubmr2.es/foro/viewtopic.ph ... 8accbf517f
Good god man... dont you have work to do?
Its on a lot more then that....
I like the spanish one though, shame I cant speak it.
phone: 01209 202944
phone: 01209 202944
Post it as many times as you want Guy, it saves the rest of us trying to explain, very badly
I think I should be using 5w-40 not 10w-50 (never go above 112 deg C) which is a bit annoying as I just bought 10 litres off you. Nevermind, next time...
In the world of oil Guy is...well the guy! Fantastic info explained in an idiot proof fashion as per usual mate. Keep up the good work
MikeJC
MikeJC
