Let's clear up a common misconception (oil viscosity)
Goto page 1, 2  Next
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> IMOC-UK Affiliates -> Opie Oils
Author Message
oilman
IMOC Affiliated Company
PostPosted: Wed Jun 01, 2005 12:46 pm    Post subject: Let's clear up a common misconception (oil viscosity) Reply with quote Reply with quote including images
I read on many forums about 0w and 5w oils being too thin. I will try to explain it without getting over technical and we'll go from there.
0w-40, 5w-40, 10w-40 and 15w-40 are all the same thickness (14cst) at 100degC.
Centistokes (cst) is the measure of a fluid's resistance to flow (viscosity). It is calculated in terms of the time required for a standard quantity of fluid at a certain temperature to flow through a standard orifice. The higher the value, the more viscous the fluid.
As viscosity varies with temperature, the value is meaningless unless accompanied by the temperature at which it is measured. In the case of oils, viscosity is generally reported in centistokes (cst) and usually measured at 40degC and 100degC.
So, all oils that end in 40 (sae 40) are around 14cst thickness at 100degC.
This applies to all oils that end in the same number, all oils that end in 50 (sae 50) are around 18.5cst at 100degC and all oils that end in 60 (sae 60) are around 24cst at 100degC.
With me so far?
Great!
Now, ALL oils are thicker when cold. Confused? It's true and here is a table to illustrate this.
SAE 40 (straight 40)
Temp degC.........................Viscosity (thickness)
0..........................................2579cst
20..........................................473cst
40..........................................135cst
60..........................................52.2cs t
100........................................ 14cst
120.........................................8.8cst
As you will see, there is penty of viscosity at 0degC, in fact many times more than at 100degC and this is the problem especially in cold weather, can the oil flow quick enough to protect vital engine parts at start up. Not really!
So, given that an sae 40 is 14cst at 100degC which is adequate viscosity to protect the engine, and much thicker when cold, how can a 0w oil be too thin?
Well, it can't is the truth.
The clever part (thanks to synthetics) is that thin base oils can be used so that start up viscosity (on say a 5w-40 at 0degC) is reduced to around 800cst and this obviously gives much better flow than a monograde sae 40 (2579cst as quoted above).
So, how does this happen, well as explained at the beginning, it's all about temperature, yes a thin base oil is still thicker when cold than at 100degC but the clever stuff (due to synthetics again) is that the chemists are able to build these oils out of molecules that do not thin to less than 14cst at 100degC!
What are the parameters for our recommendations?
Well, we always talk about good cold start protection, by this we mean flow so a 5w will flow better than a 10w and so on. This is why we recommend 5w or 10w as the thickest you want to use except in exceptional circumstances. Flow is critical to protect the engine from wear!
We also talk about oil temps, mods and what the car is used for. This is related to the second number xw-(XX) as there may be issues with oil temperatures causing the oil to be too thin and therefore the possibility of metal to metal contact.
This is difficult to explain but, if for example your oil temp does not exceed 120degC at any time then a good "shear stable" sae 40 is perfectly capable of giving protection.
"Shear stability" is important here because if the oil shears it thins and that's not good!
However, if you are seeing temperatures in excess of 120degC due to mods and track use etc then there is a strong argument to using an sae 50 as it will have more viscosity at these excessive temperatures.
There are trade offs here. Thicker oils cause more friction and therefore more heat and they waste power and affect fuel consumption so it's always best to use the thinnest oil (i.e. second number) that you can get away with and still maintain oil pressure.
There is more but this post is too long already so lets keep it to basics.
Guy
_________________
Use the code IMR2OCUK and get 10% Club Discount
oilman's website: http://www.opieoils.co.uk/ register for news and offers
email: [email protected]
phone: 01209 202944
Back to top
User is offline
cantfindausername
PostPosted: Wed Jun 01, 2005 1:26 pm    Post subject: Reply with quote Reply with quote including images
Useful info for sure. Maybe one for the knowlegde base.
My car is gonna mainly live on the red line as it will be used mainly on the track once its built. So for this what would you recommend after run in?
Ant
Back to top
User is offline
oilman
PostPosted: Wed Jun 01, 2005 4:28 pm    Post subject: Reply with quote Reply with quote including images
If the car is going to spend most of its time on the track I would go for the Silkolene Pro R 15w-50 as the top option.
Tech data here http://www.opieoils.co.uk/lubricants.htm
Guy.
Back to top
User is offline
Mark Edwards
1990 Toyota MR2 Mk2 Turbo Rev1
PostPosted: Wed Jun 01, 2005 4:33 pm    Post subject: Reply with quote Reply with quote including images
Thats great and informative info and explains the second number brilliantly, but a bit more about the first number would be interesting too. I get it that for the main use my car gets, that i need to be using a xW 40 oil, but what first number should i use? I usually stick with the stock recommendation of 10w 40 but i don't know why?
Back to top
User is offline
oilman
PostPosted: Wed Jun 01, 2005 7:53 pm    Post subject: Reply with quote Reply with quote including images
Mark,
The best way to illustrate this is by putting up some more numbers but before I do that, remember that at 0degC, 10degC and 40degC the oil is thicker than at 100degC.
The "w" number actually stands for "winter" and it's the "cold crank viscosity" of the oil.
The thickness of the oil varies dependent on viscosity but, here are some examples.
0w-20..at.......... 0degC = 328......at 10degC = 181......at 100degC = 9
5w-40..at ........................811........................421..........................14
10w-50.at.......................1039........................539.........................18.5
15w-50.at.......................1376........................675.........................18.5
20w-50.at.......................2305.......................1015........................18.5
Obviously the thinner the oil the better the flow at 0degC and 10degC.
If you understand my two posts then you will now be getting the picture of what's best. You need an oil that flows quickly at cold start protecting the engine from wear (5w and 0w do this best) and an oil that will protect your engine when hot depending oil oil temps.
A very good grade for both top and bottom protection is 5w-40 which is very suited to European climates and is more shear stable than 0w-40.
Hope this helps,
Simon
Back to top
User is offline
Mark Edwards
PostPosted: Wed Jun 01, 2005 8:01 pm    Post subject: Reply with quote Reply with quote including images
Yeah, that all makes perfect sense now.
Thanks [Wink]
Back to top
User is offline
raptor95GTS
PostPosted: Wed Jun 01, 2005 8:35 pm    Post subject: Reply with quote Reply with quote including images
yup, top info Simon =D> . Defo a sticky in my book
Back to top
User is offline
Baker
PostPosted: Wed Jun 01, 2005 8:48 pm    Post subject: Reply with quote Reply with quote including images
but why does myNA leak when using 0-40, but nothing leaked when i used 15-60? is that not the thickness?
Back to top
User is offline
jonb-
PostPosted: Wed Jun 01, 2005 8:58 pm    Post subject: Reply with quote Reply with quote including images
Fantastic information... now if you could do what no man has done before and explain the exact differences between torque and bhp you'll get a medal [Wink]
Back to top
User is offline
ENSMR2
PostPosted: Thu Jun 02, 2005 7:26 am    Post subject: Reply with quote Reply with quote including images
So what does the 5w mean and what does the 40 mean [Confused]
Back to top
User is offline
cantfindausername
PostPosted: Thu Jun 02, 2005 8:00 am    Post subject: Reply with quote Reply with quote including images
Thats gotta be a joke [Laughing]
Thanks for all the info. Has definately cleared alot of confussion up.
Back to top
User is offline
ENSMR2
PostPosted: Thu Jun 02, 2005 8:25 am    Post subject: Reply with quote Reply with quote including images
Yes [Laughing] Just thought it funny how the thread starts with
and then started very technical lol.
Back to top
User is offline
BenF
Premium Member
2003 Toyota MR2 Mk3 Roadster Turbo
PostPosted: Thu Jun 02, 2005 10:43 am    Post subject: Reply with quote Reply with quote including images
Great post - now in the Knowledgebase -
http://www.imoc.co.uk/forums/kb.php?mode=article&k=65
(c'mon people, you can submit these articles yourselves you know!) [Wink]
Back to top
User is offline
JohnA
Guest
PostPosted: Thu Jun 02, 2005 2:04 pm    Post subject: Reply with quote Reply with quote including images
After reading some earlier posts I have just bought some Silkolene 10w50 for my rev1 Turbo (fairly standard car). After reading this I think I would be better with a thinner oil....anyone want to buy an unopened 4 litre can of Silkolene PRO S Fully Synthetic 10w50?? 20 including postage.
Back to top
oilman
PostPosted: Thu Jun 02, 2005 3:51 pm    Post subject: Reply with quote Reply with quote including images
No need to change, the 10w-50 is ideal for the turbo model, the na is well suited to the 5w-40.
I would stick with it.
Guy.
Back to top
User is offline
JohnA
Guest
PostPosted: Thu Jun 02, 2005 4:01 pm    Post subject: Reply with quote Reply with quote including images
Guy
The car is near enough standard and spends most of it's life doing short journeys, also fuel consumption is horific, from what you were saying a less viscous oil could improve this and also protect better when it's not fully up to temperature.
For the sake of 30 I would prefer to go with the best option, what do you think?
John
Back to top
oilman
PostPosted: Thu Jun 02, 2005 4:14 pm    Post subject: Reply with quote Reply with quote including images
JohnA wrote:
Guy
John
John,
Its up to you, but I would be happy with the 10w-50.
Guy.
Back to top
User is offline
Baker
PostPosted: Thu Jun 02, 2005 4:30 pm    Post subject: Reply with quote Reply with quote including images
any responce to this?
Back to top
User is offline
oilman
PostPosted: Thu Jun 02, 2005 4:37 pm    Post subject: Reply with quote Reply with quote including images
0w-40 is much thinner accross the whole viscosity range then the 15w-60 so it did not leak because of how thick the 15w-60 is, however that is too thick and you engine will not have much fun pumping it around.
You need to find a happy medium.
A well maintained NA should not leak with a 0w-40.
Guy.
Back to top
User is offline
Jonesie
Guest
PostPosted: Fri Jun 03, 2005 5:36 pm    Post subject: Reply with quote Reply with quote including images
ok then,i read most of that,but i'm gona be honest and say i'm just a dumb guy as far as cars go and like to drive em,but dont know too much bout what makes em go.
With this in mind,wots the best oils to put in my rev2 turbo as its due a change and i really wanna make sure its running the best oils i can get.
It only goes on the road and i only push it when im on the motorway and somewhere nice and open,so no need for race spec oils,but something that would b good all round would b very helpfull indeed.
Thanks in advance [Rolling Eyes]
Back to top
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> IMOC-UK Affiliates -> Opie Oils All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
