Well since my last update a fair amount has happened
Firstly I finished off the rear reflectors:
Needless to say they look great on
I attended Japfest with the car and thoroughly enjoyed myself, although unfortunatley I didn't take any photos of the MR2 section.
Guess that means that I will have to go again next year
Well yesterday I got new rear tyres fitted to the car.
Unfortunatley they weren't cheap but needed to be done for the impending MOT.
I also did some minor adjustments, such as rebolting and adjusting the windscreen wipers, etc.
Today I attended a 10k in the morning and then in the afternoon it was time to set about attacking the suspension
I knew this wasn't going to be an easy job, having replaced the drop links, etc.
on the back.
But it needed to be done and today seemed as good a day as ever.
So Jack-p came down and we started to plough through it
with great difficulty and numerous trips to the local car shop! lol.
Heres my suspension all nicely set out:
Note that I don't have the front suspension top bezel cups that sit between the springs and the top mounts.
Unfortunatley I didn't think of this when ordering my parts
but we will get to that in due course! lol
After lots of WD40, some swearing, massive breaker bars, and most importantly some decent time with a blow torch we managed to crack of the main nuts holding in the suspension arms
Unfortunatley the old drop links were corroded in and refused to budge.
Whilst working out how to rip the old stuff out I fitted the drop links to the front suspension.
Anyway I worked out an action plan to angle grind the drop links off
called in a favour and a couple of minutes later it was done
- happy days
The rest was
"relatively" quick and simple, when combined with some grunts and brute force.
The old suspension strut came out and was placed next to the new for a comparison.
Needless to say that after 21 years its not looking so great!!!
A massive void awaiting new suspension
I do intend to waxoil that space, but all in good time, I've got more important things to do first such as braided brake lines
(when I finally buy some! lol)
Note the suspension bezel/cup at the top of this photo that I referred to earlier
(in relation to not having bought)
Luckily when I took the old strut apart it looked quite healthy.
In fact it looked brand new and even had the sticker still on the top
- having searched through my receipts I've found that its about 1 year old.
So no need to replace that any time soon
That got ripped out and put on the new suspension
(the only older/re-used part on a whole new suspension set up)
The new dust covers looking great
Everything got assembled correctly using spring compressors and a spare pair of hands and got re-installed.
Unfortunatley time was dragging on by now and I didn't have a chance to take any photos.
Instead I moved over to the passenger side and started work on the front there.
Within the space of a couple of hours Jack and I had also managed to switch that out.
but it didn't come without issues.
The top bezel section was badly corroded to the point that you can see light through the holes in it.
It was clearly original and had never been touched.
I patched it up as best as possible but as I was on a deadline and didn't ahve a new one the strut got fully assembled and re-attached to the car.
I now have one on order so once all of the suspension is set up and I have cleared my MOT I will drop the passenger side strut out again, dis-assemble the suspension and re-assemble it with the new part.
Its easy enough, especially now I have had all the bolts off, but it just feels like wasted time!
But anyway its looking lovely, and the car even sits lower on these springs.
I'm sure when they bed in fully in a year or two it will have a lovely stance, especially if I stick on some 5-10mm spacers
These are the only hurried photos I took of them fitted, as I as being nagged by the girlfriend for being late to dinner
but the car comes first! lol.
Unfortunatley this process makes it look far easier than it has been today.
I cannot stress how difficult it is to crack off nuts that have not moved for 21-22 years and are stubbourn as hell!!! But we got there in the end
with one last hiccup!!
We were bleeding the brakes so that the car could go for a short test drive to ensure that everything worked as it should.
Driver's side bled off fine.
Passenger side was more of an issue.
Literally looked at the bleed point, didn't even really touch it with the spanner and it fell to pieces!!
Sods law!!! Just over a week away from the MOT and I now have no brakes!!!! GGGGGGGGGRRRRRRRRR
So a passenger side front caliper is now also on order
Hopefully by the end of this coming week I get a chance to change over the calipers and the car will drive a lot better.
I can't wait to get that sorted so that I can look forward to replacing the rear suspension.
Its going to be a loverly drive when its all done
- excited doesn't cover how I feel
All in all a good day.
A few minor issues and hiccups and a lot of time swearing at stubborn bolts but a good learning curve and a new found love for blow torches and breaker bars, lol.
Here's to hoping that the next update is as poitive and the car continues its transformation into a brand new SW20 MR2 rebuilt from bottom to top with new bits
