I notice Fen Sport sell these & wonder if anyone has experience of one of these fitted to a standard mk1, i.e. how handling is affected.
I up-rated the anti-roll bar on my civic & it really helped reduce understeer.
What effect does it have on handling to increase the stiffness of the ARB? I thought I had heard that if you stiffen the rear, you increase understeer, and if you stiffen the front, you increase oversteer ... is that right or have I got it bass-ackwards?
i would have fort if you stiffen the rear, it will reduce oversteer as it keeps the rear wheels from lossing surface area on the ground. So if you stiffen front and back it would improve grip overall. That right or am i well off lol
i like the 22mm on the front of the lil feral, turn in and overall body roll has greatly improved. though i think a 20mm/18mm would be better suited combined with better quality springs/shocks. i find even with the weight of the sub in the frunk it will understeer more than i would like on tight radius's.
i also beleive that going too thick (over 16mm IMO) on the rear promotes oversteer.
it's not always a case of bigger is better IMPO.
I have the 18 mil rear and 20 mil front ARB's, they do make the car handle really well and it turns in so much better than before but found to be twitchy at the back end but I also fitted KYB's and a poly bush kit at the same time so it's very hard solid ride.(not ideal for the wet).
