Hi
Check the wires that go into the alternater multiplug are not broken in the insulation
/ sheth, had this on my REV 1 Mr2 turbo.
The vibrating
/ movment in the wires intermittanly connect causing it to charge and then disconnect so it does not charge while driving and so on.
Also make sure the contacts inside the multiplug are clean and tight fitting.
You should get when engine is running around 14.2 volts
Yes when the battery power gets low the power steering will give up as it has not enough volts
/ current to work the same as most of the other high power electrical equipment like ABS.
Hope this helps
