Apparently there is play on the arm in the pictures below, my mechanic seems to think there is a balljoint where it bolts into the crossmember?? I thought it was just a bush of sorts.
thanks
Rob
going4the1 wrote:It is called a suspension arm
See:
http://www.mr2-tech.com/bgb/mechanical/ ... d_axle.htm
Page SA-79
You are correct- there isn't a ball joint.
However there are reports that the captive nut within the rear subframe can shear off.
This means that the bolt on the inboard end cannot tighten up.
This may give the appearence that there is a worn bush.
The fix is to either buy a complet subframe or open the box-section and re-tack the nut in place.The subframe them need plating over.
