Could there be any simple/principle things I should assume not working?
The MOT garage spent 2 hours trying to adjust the lever position
Any ideas?
![Shocked :shock:](./images/smilies/icon_eek.gif)
dervbas wrote:Pic 1 shows the caliper and
"piston" yes? The piston has those two indentations on it where I can use a tool on it to wind it in or out?
How do I know when its wound all the way in? Should the black rubber around it get all caught whilst I'm turning it?
Should the handbrake be on or off for this procedure?
dervbas wrote:Pic 2 shows various other springs and nuts: do I need to"play" with these?
dervbas wrote:Pic 3 shows where the handbrake cable seems to attach to the caliper.Is that the
"pin" that attaches the end of the cable to the spring mechanism on the caliper?
dervbas wrote:Now, when I pull the handbrake the spring mechanism in Pic 2& 3 moves freefly
(as I'm sure it should).
But the piston does not move.
toxo wrote:The one that the spring sits around? From memory it just holds the parking brake crank on(the bit that's actually sprung and moves around), which has a pin on the other side of it which goes into the cylinder.
philh wrote:simple![]()
try this easier trick
save time by winding pistons back etc
TRY loosening both 10mm nuts at handbrake lever cable end untill handbrake is slack
Start engine for servo assistance pump brake pedal hard as you can for at least ten pumps then re-adjust cable by 10mm nut so h/brake lever comes up 7-10 clicks OR handbrake lever is nearley vertical, you should then have a perfect handbrake operation, if so lock-up second locknut.
JOB DONEN.B if only one side is faulty suspect h/cable seized
very common.
This is the procedure I have used in over 20 yrs working as master tech in Toyota/lexus dealers same proedure for
AW11
AE86 Corolla etc
