Was just wondering how much fuel others are using as mine seems to be just drinking it!!
I put £20 in the other day and it took it to half a tank from near empty and after 40 miles I have used over 1/4 of a tank.
Is it because im addicted to hearing the turbo spooling up most of the time? Or could it just be because Im stopping and starting all the time in traffic in town?
I have a Rev2 Turbo with a XS Dump valve fitted but I dont think this is the problem (I dont realy hit enough boost to make it dump much / any air out)
[Mk2] [Turbo] How much fuel do you use?
Re: [Mk2] [Turbo] How much fuel do you use?
Unfortunately they do drink the petrol especially when you use the turbo. Practicaly see it drop on boost
Town driving doesnt help either
I get 300 miles to a tank with mixed driving....
Short journeys kill your fuel life though
If i run to the light and put £10 in, sometimes i have used that in 2 10 mile trips!!!!
Always seems to be the last 1/4 tank that just hoovers!!
you will learn how your fuel gauge works over time...it may go down hardly any with the use of £10 petrol then go down a quarter on the next fiver....
motorway....32 mpg
cold starts....15-17 mpg
gunning it...10 mpg
town driving....15-20 mpg
mixed...your guess will be as good as mine, over time you will form your own opinion
motorway....32 mpg
gunning it...10 mpg
ah phew, so my fuel usage seems right then.
gonna have a go driving without hitting boost on my next fill up. (but its gonna be hard )
How much is a full tank in one of these? Put £40 in it the other day and took it to nearly full on the guage but it was gone within 100miles (about 70 miles of country road use up and down hills and having to slow right down to 2nd / 3rd for corners etc and the rest used in town)
Im not too bothered about the fuel useage, was more worried incase something was wrong making it use this much.
Well, i can get £50 in of the V power stuff at around £1.10 per litre, i'm sure there is probably still a fiver or so in there as the light comes on quite early.
I drive mine fairly hard when warmed up. I get around 45 miles to a tenner which works out to roughly 200 miles to a full tank (never filled it though).
I get 450-480km to a tank which isn't that bad really.....for a 2 litre turbo.....
id say 200-250 miles to a tank, thats what i get anyway
lets face it its hard not to let to turbo spool up from time to time
Just got over 280 miles on the last fill-up... with PLENTY boosting and numerous cold starts.
Yay for the Link G3!!! Mapping from Ryan 2Bar..
2bornot2b wrote:id say 200-250 miles to a tank, thats what i get anyway
I know. You want to go slow but you just cant!! Like today I said Im not going to use any boost (within reason) but when I got home and checked the Apexi SAFC it said I hit a max of 6753rpm so that plan didnt go very well
Just got some NGK Iridium Plugs, New Dis. Cap and New Rotor arm so will fit these on the weekend and see what happens.
When you say cold starts do you mean that extreme lag that you get for the first few mins of running?
Put the standard BOV back on that will make it better
IIRC a full tank is 55 litres. My fuel light comes on with about 10l left.Steve-O 2007 wrote:How much is a full tank in one of these?
As for MPG I'd agree with mrtee. I've had nearly 35 on a m'way run, typically get around 27 day-to-day. Low 20s on a blast, and under 10 is often reported on track. I try and avoid town driving as much as possible. But again the rev 1/2s often seem to get much worse figures than the rev 3.
Steve-O 2007 wrote:When you say cold starts do you mean that extreme lag that you get for the first few mins of running?
No... I mean the first start-up of the day when the engine is cold. It uses more petrol as the 5th injector is active.
I get about 250miles from 45L
I probably do more miles in an MR2 than anyone on here! 25,000+ per year (...yes, I am crazy!)
Totally stock Rev2, I'm doing 550 miles a week. I fill up 2-3 per week, to fill the tank cost between £53 and £57 each time. (£57 being the most i've ever spent to fill the tank)
I get between 230 and 270 miles per tank. I do 100+ miles a day, mostly motorway, and TBH I do not drive economically.
Lose the dump valve, it may run fine but they do not work well with an air-flow meter and will cause ti to over fuel. Plus, if you're not really boosting it enough to vent, why have it?
When my other MR2 had the Rev3 conversion, the fuel economy showed an instant improvement. (First tank was an easy 300 miles+) When I get it back it will have a link G3 so I'm looking forward to the even further improved economy.
It's a 2 litre turbo, and super-unleaded is costing well over £1 per litre, if you're concerned about your MPG, you're in the wrong car dude!
that = £6K + a year on fuel. Been a reliable car for you though
But, yeah - put the stock BOV back on.
ok going to get hold of a stock dv to put on and see what happens untill I do the rev3 conversion to remove the AFM (then it shouldnt affect fuel usage if I fit the aftermarket one again should it?)
Im not bothered about the fuel usage was just interested in how many miles others get
Once you do the Rev3 Conversion you'll be using a MAP sensor so a vent-to-astmosphere BOV will be fine, you'll also see a better return on your MPG.
Hmm, I find it hard to believe even rev 3's can get 300 miles to a tank. You'd have to pretty much not boost at all. Like I say I get 200-220 miles with mixed driving (boosting on clear roads).
Whippet, I do about 300 miles a week which I thought was a lot but that's nothing compared to you. Lol. Buy some shares in Shell mate.
