Hi guys.
Mk1 SC owner here, I've got to get my front wheel bearing sorted for the MOT in the next couple of days.
I have a blueprint wheel bearing kit that has the bearing, some grease and a new ring/seal.
In the BGB it shows also a new
"inner race" and
"o-ring" for the hub seal.
I was planning on taking it to the local garage
(the steering knuckle) to get them to swap it over
- will the contents of that kit be suffice? Maybe they have generic o-rings if need be I guess but this is NOT MRT we are talking about.
Also, as many people have taken just the hub/knuckle to a garage, is this generally with the rear hub cover on
(the one that the BGB suggests taking a hammer and chisel to) making it a two part removal process for the garage
- or have these people stripped it down completely ready to press in
/ out.
The problem is I have no vice.
and little time!
I have lowered my suspension and done and engine swap before
(both on my own) so I know a couple of things about mk1s
but have been out of the MR2 loop for a while and feel rusty
(no pun intended) on the mechanical side, and I know virtually nothing about wheel bearings except for what I read in the BGB.
cheers for any advice.
