When setting up an EBC (Blitz DSBS in this case), do you set the boost as psi or bar when programming it? Just curious as I may be getting one soon and haven't fit/used one before.
Also, do you still leave the FCD wired to the ECU from when I was using an MBC or does this need to be removed?
[Mk2] [Turbo] EBC Setup
Re: [Mk2] [Turbo] EBC Setup
You will need the FCD to boost beyond factory levels.
The DSBC does not indicate in bar or psi. it shows boost in HkPa.
(1.00 hkPa= 14.50 psi)
When setting the boost levels in the EBC, the numbers are a percentage ratio. 0 equals stock boost and 100 represents the max the turbo can achieve.
Best bet is to have it set on a dyno while monitoring with a wideband. Once its set, you shouldn't have to readjust it until you add more mods to the motor.
PFrazier wrote:You will need the FCD to boost beyond factory levels.
I've got an aftermarket boost gauge in a pod so will I just be able to plug it in on 0 and this should give me standard boost, then just adjust it bit by bit until I reach my desired boost level right?
Yes you can do that.
Have you read the install/user instructions? They are available for download on the Blitz website.
IIRC I posted install links and the owners manual in your other thread.
Isn't 1 BAR 1 hkPa anyway?
1 bar = 100 Hkpa
PFrazier wrote:Yes you can do that.
Yes but I need a proper dummies guide, step by step with pictures
This writeup is a pretty good step by step http://www.mr2.com/ARTICLE/BlitzDualSBC.html
