The garage has fitted my ATS TD06 for me and it goes well but at the moment its on standard boost.
I thought i would up the boost a couple of psi to around 17 with a grainger valve.
Basically i put the valve in line with bootom actuator pipe and turbo.
The results were just a lot of over boost and fuel cut etc so i have returned it to normal?
What did i do wrong as i thought i could run higher?
Also the garage have the top actuator pipe connected to nothing is that right?
Dave
