[Mk2] [Turbo] How can i hit 300 bhp?
pez
Post by pez »
Hi all,
At present moment everything on my tubby is standard apart from the exhaust (Apexi GT) and Air filter (HKS).
What else do i need to be able to hit 300bhp mark?
I want 300 as i do not want to do internal modification yet and i know this is the limit on a stock tubby.
Pez
tomwoodis
List
Post by tomwoodis »
I reckon you can do it with the following but to be honest whether you hit the magic 300 will depend on the overall health of the engine (im basing this on the rev 3 turbo which you appear to have)
Anyway here goes, oh and this assumes that you have serviced the engine regularly including good oils, new dizzy cap, rotor arms and spark plugs every 5-6k miles. You really must do this to run a reliable 300:
Uprated air filter - Apexi, ARC, HKS any really (people will argue that some are better than others however in reality they make little difference on a car with forced induction)
Better intercooler/chargecooler - if its a chargecooler you are after then the Celica 205CC is a good bet for the money otherwise its a good intyercooler from the likes of Greedy, Berk, Phoenix Power possibly even the XS power one will do although you are likely to have issues fitting it. As a general rule the more you are prepared to pay the better.
Boost controller - This could be a manual one but probably best to use an electronic one when running high end to make sure you have the accuracy. Also you will need an aftermarket boost guage to ensure you are running the correct boost. With this fitted the boost can be raised to 1.2bar with no need for an FCD on the rev 3 car.
Downpipe - get rid of the cat and fit a downpipe. Again there are various on the market all of which perform a similar job.
Better exhaust - get a nice free flowing exhaust with atleast a 2.5" pipe at the smallest part. There are loads to choose from so have a look around. To be honest good second hand units come up on here quite a bit.
To be honest thats about all you need although at 300hp your running close to the limits of the oem clutch so might be worth swapping that out. Also at 300hp you should really be running a grade colder with the spark plugs.
You might also consider a lighter flywheel at this point. Wont necessarily free up much power but worth doing if your doing the clutch.
In summary:
New service parts with service carried out
Uprated air filter
Chargecooler or intercooler changed
Boost controller set to 1.2 bar
Downpipe to replace CAT
Free flowing Exhaust
Colder grade plugs
Possibly a new clutch
Possibly a lighter flywheel
Right let the debate begin :thumleft:
Ian Geary
Re: [Mk2] [Turbo] How can i hit 300 bhp?
Post by Ian Geary »
fyi
a 1 grade cooler NGK plug is something with a 7 in the middle, like BKR7E.
Stock is BKR6EP-8.
Also, just in case the previous post doesn't creaet a debate, you didn't specify whether you wanted those 300bhp at the wheels, or at the fly?
300bhp at the wheels is more like 350-370 at the fly.... :whistle:
Personally, unless you've got a pile of cash waiting to be spent, I'd do the mods progressively.
the exhuast and cat I'd do at the same time, but the rest you can do bit by bit.
the biggest bit of work is the intercooler though.
I wouldn't do the clutch until it starts to slip, but one thing I'd add to Tomwoodis's list is checking the brake pads and replacing the brake fluid- this will sharpen the pedal up, and costs abour £3 for basic dot 4 fluid (if you're going on a track, shell out for dot 5.1).
hth
Ian
mattcambs
Post by mattcambs »
hth
Ian
The absolute limit of the stock turbo is about 280bhp at the wheels (~340bhp). This requires a CC, fuel pump and a fully mapped ECU running around 1.3bar and ain't cheap.
My advice is to not chase 300bhp. Tom and Ian have given great advice, which if you follow (including the brakes) will give you a very nice, quick car. Maybe it'll make 300bhp (at the fly-wheel), maybe it won't, but it will be close to this.
Totally agree that the charge cooling is the most important thing to do. I know that 3S do a drive-in, drive-out Celica charge cooler fitment. This will let you safely run 1.2bar.
gnzyza
Post by gnzyza »
sort of on topic, so what turbo will hit 300 ATW on the above setup without too much lag etc....
say if you run this new turbo at 1.1/2 bar then can you still run stock ecu- is that poss.
jonny823
Post by jonny823 »
i have a rev1 and have all the mods above and will be fitting my intercooler next week my car was 191whp when last dynoed
what gains whould i see with all these mods on the rev1 i tryed fittin my fcd 2day but got the wrong instructions so if anyone has the wireing diagram for rev1 could they post it up here
im only aiming for 1bar boost due to standard headgasket
pez
Post by pez »
Thank you all for the advice.
I want 300bhp at wheel.
I do have Apexi GT but now i guess i have to take it off again to fit a down pipe.
p.s. i have de-catted the stock downpipe. Is that good enough or do i need a proper downpipe??
I also have ct20b on my tubby. Is that good enough for 300 at wheel?
mattcambs
Post by mattcambs »
pez wrote:Thank you all for the advice.
The CT20 is NOT up to producing 300wbhp. Fozzy Rev3 made 276wbhp on his and that was with the best charge cooling available (Radtech) and a Link ECU. You will need bigger injectors for 300bhp @ wheels, plus you will also be at the limit of the standard pistons. I'm not trying to p1ss on your bonfire, but you are looking at spending at least £5000 to get 300 at the wheels.
Proper downpipe is ideal, but gutted CAT is probably 80% as good. But seeing as you'll need to swap the turbo, you might as well change it.
300 at the wheels is a great target, but it's one that unfortunately is just that little step further than the usual intake/exhaust/boost increase mods that a lot of people do.
You will need to go beyond the safe limits of the intercooler/turbo/fuel system/pistons to achieve 300wbhp and then you might as well go the whole hog and get a GT30 series turbo and have 400wbhp!
Your previous thread said you had £1000 to spend. Has your budget increased now?
Matt
tomwoodis
advice
Post by tomwoodis »
Totally agree with MATT - Great advice by the way :thumleft:
xistance
Post by xistance »
i cant belive my car is 196 at the flywheel somthing has got to be seriously wrong :-k :pale: :? that means my car is about 120hp at the wheels which my old 106 gti was :oops:
pez
Post by pez »
Well my £1000 budget has not increased but slowley i want to get the car very powerful as i do not use it that often so less tear and wear.
I guess i will be better off getting an engine re-build job with forged internals.
How much willl that cost?
mattcambs
Post by mattcambs »
pez wrote:Well my £1000 budget has not increased but slowley i want to get the car very powerful as i do not use it that often so less tear and wear.
Couldn't tell you, but as a guess: £1500? Best thing to do is talk to a couple of specialists. Rogue, 3S, Century, etc (see affiliates section) and discuss what your goals are. Then they can advise you the best order to do things so you can SAFELY mod your car bit by bit as funds permit - eventually reaching your goal.
Dude, be prepared to spend BIG time :lol: It's called the modding bug.
pez
Post by pez »
modding bug?!!!
I have had that for ages mate. I stopped for a while but i think i caught it again. ](*,)
EarL
Post by EarL »
Hope you've got deep pockets Pez...
Here's a good place to start... :wink:
http://www.imoc.co.uk/forums/garage.php ... le&CID=225
EarL.
Chr15py
IMOC Organiser
Post by Chr15py »
xistance wrote:i cant belive my car is 196 at the flywheel somthing has got to be seriously wrong :-k :pale: :? that means my car is about 120hp at the wheels which my old 106 gti was :oops:
196 at the fly = broken mr2 turbo. Check your dyno read out and find out what they were measuring. 196bhp is probably about right at the wheels.
Chris
Mr Rapey Banana WILL get you...oh yes! :)
Chr15py
IMOC Organiser
Post by Chr15py »
EarL wrote:Hope you've got deep pockets Pez...
EarL.
Link doesn't work bud - says "you are not the vehicle owner"
Chris
EarL
Post by EarL »
EarL.
Chris
Nice one Chris... :lol: :lol:
:roll:
pez
Post by pez »
My pockets are deep because of the holes in them. :mrgreen:
KrisB
Post by KrisB »
this is how i made 300 at the wheels
Engine
Greddy td05 18g turbo kit including exhaust manifold and down pipe
ATS Racing external wastegate upgrade
HKS racing intake
Radtec charge cooler
Sard 800 injectors
Arc blow off valve
Apexi power fc
Pheonix power departure exhaust
TRD engine mounts
Greddy oil cooler
Walbro fuel pump
Chr15py
IMOC Organiser
Post by Chr15py »
EarL.
Chris
:roll:
No joke, I'm being honest :D
Chris
