Now theres a question!
I used to run my SC at 24 front 30 rear.
that was on 15s though.
It worked really well, though i had very stiff sidewalls and the tyres didn't roll over at all.
Generally i'd advise a 4 psi difference front to rear with the rears having the higher pressure.
6psi difference is better on track.
I did well racing with 24/30 though i'm sure the other racers would have been shocked to know that tbh!
At the moment i'm running 28/32 which seems okay.
Because of the higher profile and more flexible sidewall i expect i'll likely run 26/32 or 28/34 on track.
HTH
