Here is the advice I've received:
Seller of CAT wrote:You can either just transfer the cat section and use the rev3 turbo 'elbow', or just use the whole assembly (which I've sent), the only difference on the CT20b is an extra stud which isn't required to get a good seal on it.
Thanks for your help
