as a rule Toyota uses fittings with washers that are attached to either the bolt or nut
so this looks like a non standard item, as such it would be difficult to identify by anyone other than whoever fitted it
the marks on it suggest it was bolted down using a
"shakeproof" washer so look for where you have one of those fitted and you may find you location
