OK, I had a go at checking this out last night.
I can confirm that the Lexus calipers fit directly onto the MR2 caliper carrier
/ torque plate
/ the bit that bolts to the hub with no issues.
With no brake pads in place the std.
15" alloy
(flat face spokes as fitted to the rev.2 on) went over the caliper and I heard a slight rubbing when the wheel was turned.
Removing the wheel I could see where it had rubbed.
The wheel has a series of raised edges on the insdie and one was catching a part of the caliper.
A Dremel removed less than 1.0mm and the wheel was able to turn with no rubbing.
I then fitted the
(newish) brake pads and bolted everything up.
The wheel was locked solid.
I could see that the outer pad was in contact with the brake disk and removing the one pad made evrything OK again.
When I get some more time I'll check that the Lexus caliper pistons are fully retracted.
The disk is also a bit rusty as the cars been stood for about 18months so I'll clean that up.
Let you know how it goes.
JB
