Passive or Active speaker set up?
How can you tell if the factory speaker set up is an active or passive one? I want to change the standard head unit and cd player in a GT tubby, to an after-market one, but don't fancy popping the amps.
Re: Passive or Active speaker set up?
mnie is active and i have a sub behind the passenger seat.
Have a look behind the seat and if there is a speaker grill there then it is active
(i think) by the way iso connectors for new stereo are
£30 for active
chriswsw20 wrote:mnie is active and i have a sub behind the passenger seat.Have a look behind the seat and if there is a speaker grill there then it is active
£30 for active
Might be wrong but wouldnt you have a sub behind both the seats for an active system?
Not for all years.
Some years got one.
some got two
Basically, if you have at least one.
it's the active system
Mixed Blessing.
You get a Sub, and amps that are probably worse than those built into a modern headunit.
Plus you get the hassle of alternator noise problems with most aftermarket headunits when trying to use the stock amps.
Bypass the Toyota system I say, and save a lot of hassle.
Paul
Some years got one.
Mixed Blessing.
Paul
I have the 8 speaker
'active' system in mine.
When I changed the std Head Unit and CD changer for an Alpine MP3 I used the
£30 active connector.
I was going to bypass the amp and buy new component speakers but I was quite surprised at how good it sounded so I haven't bothered.
Maybe a job for the future!
motep wrote:I have the 8 speaker'active' system in mine.
When I changed the std Head Unit and CD changer for an Alpine MP3 I used the£30 active connector.
I was suprised how good the standard
except jap N/A doesnt have any system in them,(in rev3) I have 4 speaker.
well.
all the better to have me own set up
well.
Cheers guys.
It had an active system.
2 subs behind the seats.
Got the correct harness and it works great.
Quite a good sound.
=D>
