Looks like they both contain pressure release valves then :-)
You can just about make out the spring in the pressure release valve here:
Closer look at the filter element:
On first appearances it looks like they are identical apart from capacity. Only thing I'm wondering now is whether the spring is rated the same. There is a different no stamped on the bottom of the valve....
