Thanks for all the comments
djlee_dj
- You're spot on about the exhaust
I need to align it better, I tried quickly to do it the other day when I was fitting the spats, but no luck
I'll wait til I have more time, and a helper and get it lined up spot on
, It basically needs to be pulled/pushed into line and then tightened there
There are a few other wee bits and pieces need sorted on the car, but with a baby due in the next few days I can't get them all done, but I will
RedMR2
- I'm not so keen on fitting the jap plate as it would project high in front of the air inlet for the radiator, but I can see your point
It would be nice to find another way of fitting it, but I don't fancy covering the intake as I said, and where it is now looks a bit more OEM than most I've seen.
I may resort to fitting brackets in the top of the intake area and putting the uk plate up top out of the way
It's a conundrum
