Ive bought myself a pair of kyb front inserts brand new just unboxed, i tried to fit them but the inserts on the car sit at the bottom of the thread and the kyb's sit flush with the top so the gland nut ive got wont screw on. Ive rang kyb and they told me you cant buy the nuts seperate so i dont know wether the car has already had aftermarket inserts on it and i could just buy them from toyota or you get different gland nuts with the kyb inserts. Could anyone shed any light on this?
MR2 MK1 KYB Insert Gland Nuts
Re: MR2 MK1 KYB Insert Gland Nuts
I just replaced the front shocks on my mk2 with KYB inserts which came with new gland nuts as they are different to those fitted on my original shocks.
KYBs should come with their own gland nuts that fit round the shocks, I'd call your supplier if they're missing from the box.
P.S don't forget to put some oil in the casing, it's not essential but helps with heat dissipation.
I bought them cheap without a box not realising that i would need new gland nuts.
Does anyone know if any other shock abosrber suppliers use the same gland nuts as KYB as i may be able to buy them seperatly from another company.
