Ceramically coating pistons?!?
What mad but potentially splendid madness is this??
![d'oh! #-o](./images/smilies/eusa_doh.gif)
matt_mr2t wrote:Ok, I'm pretty good at science normally but how could you run on water?
STUBALL wrote:If someone actually got this working they'd win the Nobel prize for science
SimonPearse wrote:Even if you had a 100% efficient engine the amount of power out of the engine could only equal the amount of power used to split the water.Since the power to split the water has to come from the alternator
(which has to be driven by the engine) then our theoretical 100% efficient engine will produce a total power output of zero.
Incidentally- a lot of people
(a generalism
- I'm not pointing the finger at anyone here) seem to get hung up on the theory that you can't get something for nothing.
ugli-stix wrote:
[particle physics mode]
(a generalism
Whilst this is true, it IS possible to SEEM like you're getting something for nothing.
For instance, vacuum energy fluctuations when virtual photons are created and destroyed around the zero-point energy of space
(e.g.
the Casimir effect) make it seem like you are getting something for nothing as the original energy source for this is the near infinite vacuum energy density.
By the way- this isn't a load of made up technobabble.
the harnessing of this
"Casimir" energy is an area of research looked into on an off/on basis by space exploratory organisations such as NASA.
[/particle physics mode]
