Speaker fitment / Wiring diagrams. please contribute!
Re: Speaker fitment / Wiring diagrams. please contribute!
I'm confused - I have the Infinity Reference in mine, and I definately had to make up some spacers to fit them?
Will be doing my Infinity Kappa's soon.... will let you know if I needed spacers.
SB wrote:I'm confused - I have the Infinity Reference in mine, and I definately had to make up some spacers to fit them?
Those were taken from the information given by sadgav.
I cant check them all!!!
I will amend them to needing spacers - how deep were your spacers needed to be?
Cheers Jon
I have JBL GT4-10 (10in) in the sub boxes, you get what you pay for, and they are cheap...but fitted, if slightly smaller than the hole.
Rears fitted were mac audio 3.5" coaxials, they fit in two of the four holes. Not bad, but not sure I'd bother again.
Tried to fit some 6.5" iNfinity Reference today, no way will they fit, I'll let you know the spacer size tomorrow when I've had another go.
Nice one mate!
=D> I had a day off work today so attacked my speaker project.. To fit Infinity Reference 6.5" in the front 24mm spacers are required, I cut some 12mm mdf spacers and glued them together, managed to do one speaker today, with a bit of luck I'll do the other one tomorrow and then I can have a go at mounting the amp under the front boot.
The 6.5" infinity reference mystery is solved!!!
Thread updated!
Cheers mate!
Thread updated!
Cheers mate!
kicker 3.5" coaxials for the rear dropped right in (if i hadnt lost most of the screws!). may need some padding to get a better sound.
Now I'm confused!!
I feel really lame telling y'all that I fitted them straight in - but as I need to tweek beneath the door panel anyway this weekend, I will supply pics to show that they just fit, without spacers and without catching on anything.
I did have to drill one small hole to fasten another screw but that was all.
I even fitted the crossover behind them....um.....
sadgav wrote:Now I'm confused!!
lol!!! dont worry about it!!
boosch wrote:kicker 3.5" coaxials for the rear dropped right in (if i hadnt lost most of the screws!). may need some padding to get a better sound.
have you got the model number?
cheers
neil
anychance of best (most appropiate) amps being added to the list? dont worry if it will start a fight!
I suppose we could add amps used and locations, i.e., ones that fit under the passenger seat!
Most apropriate will vary greatly on set up and budget! so dont think its possible to do a generalised reccommendtion,though myself and Steve at blue4ice do some amp and sub combinations if anyone is interested!
will get onto this when i have some spare time!
Infiity Kappa components 16.5 cm fitted straight in and tweaters swapped straight over
Matty_GTS wrote:Infiity Kappa components 16.5 cm fitted straight in and tweaters swapped straight over
Just fitted the same......straight swap for both woofer & tweeter
Rears - 3.5" Infinity Reference also straight swap
Rears - 5.25" Infinity Reference ... the hacksaw came out
My contribution.
Wire Colour Codes
Wiring Diagram For Premium System with 1 Sub (UK & European+Aussie)
Bob
Wire Colour Codes
Bob
I'm Going To Die Young...But When I'm Very Very Old!
Cheers everyone, will get these updated soon and the diagrams on the front page!
Neil
Neil
