I have no problem with cutting a bit of that
Many thanks
Ryan
Tallbloke wrote:Currently running some Sony 3 ways until I can be ar$ed to fit my focal components..
Remember that it you use the original wiring loom connection you wont get as clear a sound than if your speaker were run by a amp.![]()
However the standard stuff will utilise the standard tweeter
Chris
However, if you've got an amp lying about, why not stick that near your spare wheel to drive your front speakers, and then get a smallish active sub for the rear?
