Have I got the right jacking point?
dabcabc
Post by dabcabc »
Is this the correct rear jacking point for the mk2?
Argh!!!
JohnnyC
Re: Have I got the right jacking point?
Post by JohnnyC »
No, that's your gearbox :mrgreen:
In your 2nd pic, that big lump of metal going across, errr, mental block, what's it called? :roll: :oops:
jont
Post by jont »
Rear subframe?
JohnnyC
Post by JohnnyC »
jont wrote:
Rear subframe?
That'll do :) rear cross-member is what I think I forgot.
My memory ain't what it used to be, is that gas I can smell? ohhhh sh...
brb #-o
dabcabc
Post by dabcabc »
woo it's up on axle stands now....
now giving my rear wheels a lovely bath with a rubber ducky to find out where that darn slow puncture is!
tron20
Post by tron20 »
Duncan,
You may want to check the sidewall/shoulder of that deflated tyre, I've no idea how long it was flat for, but if you've been driving it flat the sidewall is likely to be damaged and bulging. I know you've had one blow out already, luckily at a slow speed, you don't want to risk another one.
Paul
JohnnyC
Post by JohnnyC »
Well spotted Duncan =D>
8-[
