I'm aware that the relevant extract from the MOT regulations manual has been scanned in, but can we do more?
How about obtaining a sample reply from VOSA stating the rules for which years of MR2 Turbos are subject to which checks?
Many thanks
Graeme
Tiamat wrote:One problem*solicitor mode* who will be responsible for if the information is wrong and someone suffers loss from it?
If it is put up then either someone needs to be responsible for ensuring it is updated and/ or you need a disclaimer.
Otherwise if someone removes their cat on the basis of the information and then suffers a financial loss because of it they may sue IMOC or the author.
You may also be infringing copyright for the VOSA details.
Speedy wrote:
Yes, it would need a disclaimer, but then like everything else posted on IMOC, you follow it at your own risk.
I can't believe that they would complain about people getting correct information, or trying to educate themselves about the MOT procedure..
Speedy wrote:Ok, we're wandering well OT now.The disclaimer is something which Ben is looking into, and hopefully we'll have something sorted.
Speedy wrote:Disagree- like everything else on IMOC, it needs to be covered with a disclaimer, provide the link as well.
Thank you for getting back to me.
I have checked the emissions database and the only similar vehicle is a
3S-GE 2.0L not a 3S-GTE.![]()
Therefore there is not an exact match in the
database so your vehicle should go through the the non-CAT test using the
default limits.
I hope this helps you but again please come back to me if I can help you
further.
Regards
Christina
----- Forwarded by Christina Kriescher/HQ/VIA on 20/06/2006 09:19
alex.wainwright@****
To:
****@vosa.gov.uk
cc:
20/06/2006 09:15
Subject:
Re: MOT Test for Japanese Import
Hi Christina,
Thank you for the reply, that was my understanding of the situation.
I'd be really grateful if you could check my car details for me please:
Model: MR2 GT Turbo
Engine Code: 3S-GTE
VIN Number: SW20-
If there's anything else you need, just drop me an email!
Thank you kindly,
Alex Wainwright
[email protected]
Sent by:
To:
************@vosa.
alex.wainwright@***********
gov.uk
cc:
Subject:
Re: MOT Test for
20/06/2006 09:08
Japanese Import
Thank you for your e-mail.
The test station has to check your vehicle details against the emission
limits included in the database.![]()
If there is no exact match for your
vehicle in the emissions database then the vehicle should go through a
non-CAT test using the default limits for a 1994 vehicle.![]()
The defualt
limits are CO<=3.5% and HC<=1200ppm
If you would like me to check if there is an exact match I would need to
have the model code, engine code and the last 7 digits of the VIN number.
I hope this information will assist you but please contact me again if I
can help you further.
Regards
Christina
To:
[email protected]
cc:
19/06/2006 09:22
Subject:
MOT Test for
Japanese Import
Dear sir/ madam,
I had my vehicle(a Japanese Import 1994 MR2 GT Turbo) MOT'd on saturday,
and was failed on emissions.![]()
Previously, the car has been put through a
non-CAT test, due to the fact that there is NO UK equivalent to this
vehicle at this age.![]()
During the test on saturday, they insisted on putting
the car through a CAT-test, which the vehicle only just failed on CO
levels.
I believe the car was incorrectly tested- I have a section of the previous
'MOT Inspection Manual' which, in section 6.4, has a flowchart that clearly
states that my car should be put through a non-CAT test.![]()
Surely there
cannot have been a retrospective change since then that means the car now
requires a CAT test??This, in effect, would be like saying a 1930's car
now requires fog lights and seatbelts!
Could you please clarify the situation for my car.
Best regards,
Alex Wainwright
