I have tried to tint my mr2 before and ended up in disaster, exactly the same happened when me and my dad tried to tint his 200sx.
Both times I said I would never try it again.
But I just can't afford the £300ish to get my windows done so I'm going to give it one last go.
Does anyone have any useful tips how to do it so I don't end up with a bin full of tint film for the third time.
Tints = Disaster
Re: Tints = Disaster
Do them in a warm dry dust free environment. Make sure the windows are chemically clean using proper cleaners. Perhaps some prep wipes used before painting things.
I think the pro's use warm water with a little soap in so they can be slid across the window surface easily. I think you need to get perhaps a hair dryer and gently heat it up once applied as well.
TBH though it'll never look great compared to a professional job.
spray the window with soapy water first (not to soapy tho) put film on, work it into position, cut around the corners, water evaporates, film sticks.
Havent done it to car windows but to the windows at work, but i think there pretty much the same.
HTH
pete
HTH
pete
Lol, surely just getting the rear 3 windows done would only cost about £100?
The trouble is you are trying to apply a flat film to a convex/concave window.... They need to be shrunk into place..
Fimmo over on OC sells pre shrunk and cut film for the mk2.
Someone has said they can do the rear window, two rear quarters, two side windows and t bar pannels for £100
Sounds good to me
Sounds good to me
calll a professional. Dont waste money and time on something you need to b skilled for
remove the window and do it inside! This way you can do it comfortably with no wind! If you get any small bubbles after heating and squeegeeing (not spelt right) out willy a small hole with a scalpal and gently ease the air out - you will never know!
I typed willy a small hole and it now says willy
I typed *p r i c k* a small hole and it now says willy
I tinted my back windows last week, also made paper templates. Unfortunately the film I used was crap as came from eBay for about £2.00 and was scratched before I put it on, however I did manage to get them on without bubbles or gaps and was quite impressed with my handy work so will defiantly have another go with better quality film. Its all about taking your time and lots of soapy water.
