Well, I started this in 2002 with a rev4 GT turbo imported directly from Japan.
I sourced the car for
£8k with the intention of using it as my road car for a couple of years and then converting it into a track car.
I had it about 4 weeks before I wanted more power and took it to Owens for a unichip
- it was a total disaster, Owens said they put more boost in but the car just wasnt responding.
When I got back home I did a compression test and found that number 3 cylinder was way down on compression.
I decided that a full rebuild would be a good idea, so I took it to Noble Motorsport's in Chesterfield.
I told them I was looking for about 350bhp and intended to use it on track.
At this stage the spec looked like this.
Motec M4 Pro ECU
HKS 264 Cams
CP Pistons 8.8:1
Owens Stage 4 CT26
Greddy IC
She made about 330bhp at the fly for 1.7 bar, but I wasnt really happy
- the torque was missing low down and it was really intermittent, sometimes I would get loads of power sometimes it would seem really weak.
Mark at Owens told me it was a cooling issue and that the turbo was producing way too much hot air for the size of intercooler I was running.
I then got in touch with Patrick, who had recently set up Rogue Systems about using a ST205 chargecooler.
Patrick said he was actually working on a new system with Pace
- I quickly volunteered my car to be used as a guinea pig!.
Pace CC made a dramatic difference, it went back to Owens, had some fuel removed and she hit 365bhp.
About this time my turbo died a sudden death on track, when the air filter pipework came loose and it sucked in a foreign object
- bang!.
A few phone calls and I had myself a reconditioned GT28 from Fensports Celica!.
This was fitted, but it was obvious something wasnt quite right.
It felt more torquey than the CT26 but the top end was pretty weak.
Almost 12 months passed, with blame going from CC to Turbo, over and over until Dino contacted me with a view to test out his new CC core, which he felt would be perfect for my use.
We fitted the new CC core which made a dramatic difference, however disaster struck on the way home, the block cracked on cylinder
#3.
I always knew that the later rev3 blocks were prone to cracking
- now I had found out the hard way!.
Build
#2 was really straightforward, same components except for JE pistons
(off the shelf)
- new thick walled block was used too!.
The new build felt better from the start, although we had teething problems with the head gasket and valve train.
Once these were fixed the car was running really sweet
- actuator at 1.2 bar and she was flying.
A trip to Dave Rowe at Motec to get some more boost put through her and more problems began
- the turbo just wouldnt make any more than 1.2 bar at redline.
Lots of head scratching and I eventually sent the turbo back to Turbo Dynamics
- they delivered the bad news
- its knackered mate, aluminium stuck in the exhaust wheel which is making it out of balance.
They recommended using a slightly different turbo, a GT3071
- rated at 450bhp and it was much more efficient that my old GT28, they could re-use most of my turbo except for the
"middle bit".
The new turbo went on
- the difference was amazing!
With a 1.2 bar actuator and the Motec boost control switched off the car pulled like a train, it was easy to control, making loads of boost by 3.5k and was an absolute dream!.
Another trip to Dave Rowe and we had a flat 1.7 bar boost curve, loads of ignition advance and it was making loads of power.
The head gasket issue reared its ugly head again during this mapping session, so we stripped it again and sent the head of to an expert.
He said the finish put on by the previous maching shop wasnt good enough
- he fixed it up and sent it back.
We slapped it together, all ready to test and then the prototype CC core I fitted last summer sprung a leak and poured water everywhere!.
So, now I have the car making loads of power
- HG is fixed and im just waiting for Dino's fabricators to send me the all new CC core and super new front rad.
Once thats installed shes all done
- honest
Current spec
Motec M4 Pro
(Dave Rowe!)
HKS 264 Cams
JE Pistons
(9:1 cr)
Garrett GT3071 Turbo
Dinos CC and Front Rad
TRD Rear Diff
335mm big brake upgrade
(front and rear)
TRD ARB
JIC Front and Rear ARMS
JIC Lower Brace
Cusco Strut Braces
Custom Suspension
235x40x17 Front
255x40x17 Rear
Defi BF's
(Fuel Press, Oil Press and Boost)
Plus loads of other stuff I have forgotten.
Neil.
