OK, so whats this all about? well, essentially its the current state of my MR2 Turbo trackday car.
Its been 2 years in preparation and now is
*almost* complete, I say almost because these things are never really finished!.
The full story behind the cars development is available here
http://www.madcat.co.uk/mystory.html
This page is intended to be a quick list of the current state and my thoughts on some of the mods.
Website
http://www.madcat.co.uk/currentspec.html
ENGINE
: Built by John Noble Motorsports in chesterfield
* CP 8.8:1 Forged Pistons and Rings.
* Balanced and Straightened Bottom End.
* Fidanza Flywheel.
* HKS 264 Cams with HKS Vernier Pulleys.
* HKS 1.2mm Metal Headgasket.
* Ported Exhaust Manifold.
* Blitz 850cc Sidefeed Injectors.
* ARP Headstuds.
* ARP Valve Springs.
* Mobil 1 15w50 Fully Synth Oil Every 3k
CLUTCH
/ DRIVE: Specs Stage 2 Clutch
/ TRD Clutch Diff
* Specs Stage 2 US Clutch.
* 420 lbft Torque Max.
* TRD Plate Type Rear Diff.
TURBO
: Fensports Garrett GT28 kit, supplied second hand but recondition by Turbo Dyanamics
* Compressor A/R
: 0.70
* Compressor Wheel
: T04s
* Exhaust A/R
: 0.64
* Exhaust Wheel
: GT28
* Power Rating
: 420bhp
* NOTE
(Andy Ran 465bhp with the 264 Cams).
* See Fensports Website for Full Details
* Turbo Fitting and Enthusiasm supplied by Brian
(Powerhouse Engineering
- 01332 366588)
ECU
: Motec M4 Pro, Controlling Boost, Timing and Fuel
- Original ECU Removed
* Microprocessor 32 Bit 33 MHz with Time CO Processor
* Maximum RPM
>15,000 RPM
* Fuel Accuracy 0.00001 seconds
* Fuel Main Table
(3D) 40 RPM sites x 21 Load sites
(840 points)
* Fuel End of Injection
(3D) 20 RPM sites x 6 Load sites
* Boost Main Table
(3D) 20 RPM sites x 10 Throttle sites or 10 Gear sites
* Memory Size 512 KByte
* Logging Rate 1~20 sets
/ sec
* See Motec Website for Full Details.
* Mapping by Mark at Owen Developments and Peter at Thor Racing
INTERCOOLING
: Pace
/ Rogue Systems Chargecooler with front mount pre rad.
* Rogue Systems Engine Lid Fans
(Awesome!@#)
* Chargecooler fits in stock location
(Prevents heatsoak)
* Front mount pre rad.
* High Flow pump.
* Totally replaced pipework, inc lagging.
* Intake temps down to
~40 degrees with Hybrid CT26.
* NOTE
: Core is restrictive
> 1 bar
(360bhp Absolute Max).
* Currently planning something that will flow
~500bhp
- watch this space.
SUSPENSION
: Koni Sport
/ Eibach Pro Sport
/ HKS
/ TRD
/ Suplerflex
* Revision 1 Rebuildable Struts.
* Koni Sport Adjustable Inserts.
* HKS Adjustable Pillowball Top Mounts.
* Eibach
-25mm Pro Sport Springs.
* TRD 22mm Anti Roll Bars.
* Superflex Bushes.
* Suspension work by Jeff Fowkes
* HKS Parts supplied by MTTE, Bushes from Fensport, evertything else was pre used,
WHEELS
: OZ Superleggera Matt Silver 17x8.
* 17 x 8J Matt Silver
+35mm Offset
* 215x40xZR17 Bridgestone S03 Fronts
* 235x40xZR17 Bridgestone S03 Rear
* Supplied by Wheel Base
BRAKES
: HiSpec 325mm Billet 4's on Front and HiSpec 325mm Big Disc with stock calipers on rear
* 325mm Grooved Discs.
* Billet 4 Callipers.
* Ferrodo DS2500 Brake Pads on Front
* Toyota Brake Pads on Rear.
* Aluminium Mounting Bells.
* Mounting Kit for Stock Rear Callipers.
INTERIOR
: Corbeau Carrera Seats, Isotta steering wheel and gear knob
* Motorsport Recliners
* Sliding Seat Rails
* Comfy
* Soon to Be Replace with Sparco Pro2000's due to Weight.
(If I can get the cat out of them first!)
EXTERIOR
: Davlyns Bodyshop
, TRD Rear Wing, Bomex Side Skirts
* TRD
"Style" Rear Wing
(Erebuni)
* Bomex Side Skirts
(Unknown Copy)
* Intake Mesh
(Davlyns Bodyshop)
* All work performed by Davlyns Body Shop
