Hi all,
Sorry about the panic, but I'm running out of time.
I've taken everything step by step, but something is confusing me.
I've replaced my clock face with a 180mph UK Turbo face - CHECK!
Fitted the twosforus delimiter/ converter, I've taken off the self test beacuse I didn't want it on.
With the switch in the MPH mode, the speedo reads as if the old KPH face is still on (30mph being about 1/3 up the scale)
Whereas when I flick the switch into the "up" position (KPH) then it seems to slow the needle down, and its confusing me which one is correct.
The simple tests I've done are:
2k rpm in 3rd = 30mph
3k rpm in 2nd = 30mph
If this is correct, then I'll keep the switch on KPH, despite it being in MPH.
Another thing, my tripometer, and mileage counter are still whizzing up as if its kilmoetres
HELP PLEASE!!!
URGENT - Confusion over twosforus delimter/ mph converter...
Re: URGENT - Confusion over twosforus delimter/ mph converter...
as long as you have a 180kph speedo i.e. an import, the KMH switch will turn it into MPH.
what speedo have you got fitted behind your 180mph face? what did the speedo go upto before the 180mph face?
if you leave the sweep test function on it will sweep to 120mph then 60mph then 0mph when you turn the ignition on
i'm such a numpty!
behind my 180mph uk face, i have KPH clocks
before i changed the face, my speedo went to 180kph, and 110mph
thats cool, just flick the switch onto KMH then - job done
if you want to turn the sweep off, have it on KMH, then with the ignition on, flip it to MPH then back to KMH
sorted!
turned the test/ sweep off for now, as I'm curious to see how many miles I get from a full tank, and with the sweep on - everytime it happens it puts miles on the tripometer
Thanks for your help Steve!
no problem mate, glad i could help
The idea behind the switch is if you have a KMPH speedo you set the switch to KMPH. If you have a MPH speedo you set the switch to MPH. In both cases the speedo will read in MPH.
I thought the switch was "what do you want it to read in"
Not "what clocks do you currently have"
Just looking as I am after a delimiter/convertor, does the self test really put miles on the trip? and if so how many?
Also if anyone has got one for sale I would be interested as Twosrus have sold out
Mark
Mark
Import wrote:sorted!
When I have my delimeter in test mode in adds .1 miles to the mileage reading every time I turn the ignition on. Very handy function to have though, especially if you take off the speedo needle, loose the spring pre tension and need to re-calibrate the speedo again Managed to put 5 miles on the car that day without actually moving
unyonion wrote:Just looking as I am after a delimiter/convertor, does the self test really put miles on the trip? and if so how many?
Mark
Stef emailed me last night. Back in stock
I ordered one tonight
Dave
89 SC - Beauty.
Also to answer the question about the sweep - yes it does put miles on the clock
Just one of those little annoying things, but really when you consider the mileage you probably cover, it's negligible (well doesn't really bother me anyway).
Just out of interest, does anyone know why it performs the sweep?
Helen
Helen
Isn't it so you can calibrate it?! Say, you remove the needle its a pain to put back the needle in the original position as you cant just put it at 0 or the rest pin. The speedo will read wrong and instead of driving around with a gps and maintaining that speed with the dash out and trying to stick the needle back in at that speed (right place) whislt keeping an eye on the road. The sweep goes to 120? as to check if your speedo it correct, thus making it easier to calibrate.
That's what i've read up somewhere..
C50 wrote:Isn't it so you can calibrate it?! Say, you remove the needle its a pain to put back the needle in the original position as you cant just put it at 0 or the rest pin. The speedo will read wrong and instead of driving around with a gps and maintaining that speed with the dash out and trying to stick the needle back in at that speed (right place) whislt keeping an eye on the road. The sweep goes to 120? as to check if your speedo it correct, thus making it easier to calibrate.
The sweep test is there for two reasons, 1) because people asked for it. 2) so people can check if the needle is in the right place.
If you flick the switch across to the other position and back while the ignition is on, it turns off the sweep test. There are some people who wanted the sweep to look cool, but because of the way the speed and ODO are inextricably connected they have to suffer the clocking up with each test.
The sweep is also a good test system check too. If it doesnt sweep and you have that activated you know its broke.
