[Mk2] [Turbo] ARP Main Studs - Sump modifications required for clearance?
rossonza
Post by rossonza »
Hi guys,
im buying all the bits to forge my engine at the moment, and found some chatter on some US forums from 2010 ish stating the main studs if using ARP are too long and hit the sump the flywheel end of the engine.
Has anyone modified their sump? or used toyota bolts instead etc?
Ross
simpson_eh
Re: [Mk2] [Turbo] ARP Main Studs - Sump modifications required for clearance?
Post by simpson_eh »
yeah i had to modify mine, few people just leave that one as standard
If you see an MR2 with a raised engine cover, the bottom line is it's probably faster than your car.
rossonza
Post by rossonza »
simpson_eh wrote:yeah i had to modify mine, few people just leave that one as standard
any pictures/details of the mod you performed? wasnt sure how i felt using a stock bolt on one end.
rossonza
Post by rossonza »
Found these on ko racing site.
simpson_eh
Mine was ally filled by a shop then ground out all my pics were of twobrutal but that's gone now my mechanic put them all up :(
rossonza
Post by rossonza »
simpson_eh wrote:Mine was ally filled by a shop then ground out all my pics were of twobrutal but that's gone now my mechanic put them all up :(
thats ok mate, no worries. i guess ill see how it goes as thats a rev2 sump above and ill be running rev3 setup.
