The process of replacing a good length of the will is relatively easy for a body shop esp as now they are available to buy.
There was also a guy on eBay seling rear half and arch repair pieces.
However once the outer will is cut off it will reveal some box sections that will be sooo rusty and need cutting out and replacing with hand built replacement.
I've all new metal in there then a healthy dose of dynax inside all the cavities should keep the for away for a few years.
