Him
Any know the part number for this, I presume there is meant to be plug in that hole? Looks like I have a major rust nightmare ahead of me
I had a look in the BGB but couldn't see any reference to this area.
Thanks,
T
[Mk2] [Turbo] Underbody drain hole rust
Re: [Mk2] [Turbo] Underbody drain hole rust
Those bungs used to be fitted at pdi, they came in the glove box. The holes are for strapping down while on the car transporter.
Sorry I don't have the part number.
Get that area wire wheeled and coated in some rust converter like hammerite kurust or something similar then paint. Only problem will be there is little you can do to preserve the inside of the sill so just do your best to get some kurust on the surfaces on the inside.
mr2garageswindon wrote:Those bungs used to be fitted at pdi, they came in the glove box. The holes are for strapping down while on the car transporter.
What is PDI?
T
Ahh Pre-Delivery -Inspection -:)
tiff_lee wrote:Get that area wire wheeled and coated in some rust converter like hammerite kurust or something similar then paint. Only problem will be there is little you can do to preserve the inside of the sill so just do your best to get some kurust on the surfaces on the inside.
you can, get a waxoyl gun and squirt some up the hole using one of the many attachments you can get for them to get it right in there...
qwakers wrote:tiff_lee wrote:Get that area wire wheeled and coated in some rust converter like hammerite kurust or something similar then paint. Only problem will be there is little you can do to preserve the inside of the sill so just do your best to get some kurust on the surfaces on the inside.
Yeah fair one, I completely forgot about stuff like that. Years ago I had some of this
http://www.bilthamber.com/corrosion-pro ... /dynax-s50
the applicator was a long flexible hose and the nozzle sprayed in 4 directions (all 90 degs to one another).
tiff_lee wrote:qwakers wrote:tiff_lee wrote:Get that area wire wheeled and coated in some rust converter like hammerite kurust or something similar then paint. Only problem will be there is little you can do to preserve the inside of the sill so just do your best to get some kurust on the surfaces on the inside.
Thanks for the link
