I'm looking at having some front springs made for my car. I've took a lot of weight out the car, especially at the front. Im going to have the company in this link make me a softer spring. The car tends to bounce a bit at the front with this weight loss, so I'm thinking a softer spring will help with this?. Can anyone tell me if all the mk2 front spring rates are the same or do the differ from turbo to n/a.
www.shock-factory.co.uk/sheffield-home.html
[Mk2] [Generic] Springs
Re: [Mk2] [Generic] Springs
Found this, may be of use to someone.
1991 Turbo
F: 130lb/in. linear
R: 209lb/in. linear
1993 (don't know whether NA or Turbo, is there a difference?)
F: 130lb/in. linear
R: 210lb/in. linear
Suspension Techinique
F: 98-150lb/in (progressive) 1" drop
R: 179-235lb/in (progressive) 1" drop
TRD
F: 168lb/in (supposedly progressive, haven't seen the range though)
R: 308lb/in (same as fronts) both are 1.0" drop
Eibach Pro-Kit
F: 100-210lb/in. progressive, 1.0"
R: 140-303lb/in. progressive, 1.0"
Eibach Sportline
F: 74-189lb/in. progressive
R: 120-348lb/in. progressive
Tokico
F: 126lb/in. (supposedly progressive) 0.75"
R: 141lb/in. (supposedly linear, sounds way too soft) 0.75"
H&R Sport
F: 230-260lb/in. progressive 1.4"
R: 235lb/in. linear 1.3"
Tein S. Tech
F: 154lb/in. 1.5"
R: 274lb/in. 1.7"
HKS SF5
F: 46mm, 1.81"
R: 25mm, 0.98"
RS*R Down SUS
F: 176lb/in. 0.8"
R: 279lb/in. 1.0"
RS*R Heavy Duty Race
F: 201lb/in. 0.8"
R: 346lb/in. 1.0"
kg/mm S21 Race
F: 165lb/in. 46mm, 1.8" i think
R: 240lb/in. 25mm, 0.98" i think
Tanabe SUSTEC GF210
F: 2.3kg/mm=129lb/in. 1"
R: 4.1kg/mm=230lb/in. 1"
Espelir Active GT
F: 2.8kg/mm=157lb/in., 40-45mm, 1.57"-1.77"
R: 5.2kg/mm=291lb/in., 30-35mm, 1.18"-1.38"
Eibach Sportline
F: 74-189lb/in (progressive)
R: 120-348lb/in (progressive)
1991 Turbo
F: 130lb/in. linear
R: 209lb/in. linear
F: 130lb/in. linear
R: 210lb/in. linear
TRD
Eibach Pro-Kit
Eibach Sportline
Tokico
H&R Sport
Tein S. Tech
F: 154lb/in. 1.5"
R: 274lb/in. 1.7"
HKS SF5
F: 46mm, 1.81"
R: 25mm, 0.98"
RS*R Down SUS
F: 176lb/in. 0.8"
R: 279lb/in. 1.0"
F: 201lb/in. 0.8"
R: 346lb/in. 1.0"
kg/mm S21 Race
Tanabe SUSTEC GF210
Espelir Active GT
Eibach Sportline
Also looking at custom springs for my setup for the same reasons.
What shocks are you running?
It's not just picking a softer setting, you need to work it out. This is a good start.
http://www.hypercoils.com/spring-calculator
I've got standard rev3 turbo suspension all round. I know it's not very scientific but I was just going to order a 110lb spring rather than the standard 130lb spring. I don't think they cost that much. You could have a couple of goes at it till it feels right. I'll give them a ring and explain things and see what they say.
Turns out that these guys are the only ones with a mandrel big enough to make the front springs. I'm going to send them a set of springs so they can see what I've got and then have them make me a set to my specs. www.coilsprings.co.uk
